R channel louder
R channel louder
Post by dlyz on Sun Oct 10, 2010 6:30 pm
Hi guys, wish to seek advice. Im using Marantz PM7001 int amp. My R channel is louder than my L. I have tried different source and still the same so i concluded is amp.
I measured it with spl meter from 20 cm away in front of the speaker with white noise. R channel consistently 2db louder. This throws off the center imaging.
The problem i face now, i dont know when this problem started, when i got the amp 1.8yrs ago or last week. As long i remember i had to slant my head to the left a bit more to get a good centre image. But i thought it was due to room cos it was closer to right wall. But last week, i forgot to turn off my amp and i covered it with a cloth to protect from dust, then turn off the main switch. The volume was set to 0. The next day, my sister turn on the main switch cos she wanted to use the computer, then the amp powered on under the cloth. It remain on for 4hrs b4 i noticed. I removed the cloth and off the amp cos it was so hot, but i can still touch it... took 20min to cool back down b4 i dare to test the amp. Amp tested ok.
But i was still worried so i payed very very close attention to the sound b4 i realise it might not be my ear which is imbalance (i had a bad infection to my R ear a few years back that lead me to doubt my hearing sometime). This is when i decided to measure the L and R channel. When i use the balance control, reduce R in favor of L, wow i get a good image.
What i want to know is, is this normal in amps? as in not all amps have perfect L and R or that it can degrade in time. Is something broken or degraded in my young amp? Or shud i ignore it and continue to just use the tone control to balance the channel.
Thanks.
dlyz
Club Member
Club Member
Male Number of posts: 25
Registration date: 2009-03-27
Re: R channel louder
Post by boxer on Sun Oct 10, 2010 11:07 pm
have u tried to change yr spks from left to right? might be yr spks faulty....
boxer
Male Number of posts: 234
Registration date: 2009-03-05
Post by kancan on Sun Oct 10, 2010 11:42 pm
If All not work. Try to reposition back your balanced L/R volume, maybe you can try take out your balanced knob from inside and reposition, and adjust to right sound. I'm try before with my arcam delta, and its work. Might have dust, try clean. Very Happy at all end not workout asked for professional serviced. Laughing
kancan
Male Number of posts: 164
Registration date: 2009-03-04
Post by WongKN on Mon Oct 11, 2010 12:10 am
If I were you, I would pay a bit and get the amp properly checked.
WongKN
Moderator
Moderator
Male Number of posts: 1774
Registration date: 2009-01-20
Post by dlyz on Mon Oct 11, 2010 9:36 am
Em, i have tried with 2 different speaker. Same prob.
Hmm, im not good in electronics or DIY, i think i will go get a quote on how much is checking fee.... but after thinking long and hard... i think the amp been this way since day one. Just tat i always tot is my ear problem or room problem. And never thought about it till now.
But there is no distortion, noise, or funny sound in my amp, when i get the balance right.... its nice. Im just not happy that my amp isnt perfect, as im very protective of it Sad
dlyz
Club Member
Club Member
Post by hoyhoysum on Mon Oct 11, 2010 10:14 am
If i were you i just balance it right with the balance control. That is the purpose of the balance knob. If it is not broken do not open the amplifier. When it does ask the technician to look at your inbalance issue.
hoyhoysum
Male Number of posts: 188
Registration date: 2009-02-06
Post by WongKN on Mon Oct 11, 2010 11:07 am
If the amp is from a reputable manufacturer, then it should have gone through at least the basic QC. Given that, it is highly unlikely that it will play with a channel imbalance. This means there is very likely a problem with the amp, perhaps some component is starting to fail, or hopefully some more trivial problem like bad contact or bad soldering joint etc. This was the basis for my suggestion.
WongKN
Moderator
Moderator
Post by dlyz on Mon Oct 11, 2010 3:20 pm
oic, i think will get it checked. hopefully its not too expensive.
does hifi shop charge checking fee, or they only charge if there is repair/parts replacement? (noob here)
dlyz
Club Member
Club Member
Post by WongKN on Mon Oct 11, 2010 3:32 pm
Yes, almost all of them do. If not, they will become a free checking center.
WongKN
Moderator
Moderator
Post by hoyhoysum on Mon Oct 11, 2010 5:53 pm
If they do not charge give them some kopi money lor. Make friends with them maybe later on can be free. Some have families to feed, place to rent, utilities bill, pay their workers and lastly amortised their test gears.
Ask how much diagnostic fee first before proceeding.
hoyhoysum
Post by azri on Mon Oct 11, 2010 8:45 pm
have you tried different interconnects between source & amp?
azri
Male Number of posts: 1036
Registration date: 2009-01-21
Post by sph on Mon Oct 11, 2010 9:43 pm
How about crossing over the interconnects from source to amp. The problem could also be from the source.
output ..... ... input
CD left --------> right Amp
..... right ------- > left
Last edited by sph on Mon Oct 11, 2010 9:45 pm; edited 1 time in total (Reason for editing : error)
sph
Male Number of posts: 101
Post by 7810sam on Mon Oct 11, 2010 11:44 pm
Better confirm the source of the fault, like swapping ic and speaker cable from L to R. If it's indeed the amp fault, better send back to sole agent in malaysia for check out before smoke coming out from the amp(possibility). Unless you are looking for excuse to upgrade.
7810sam
Regular
Regular
Male Number of posts: 94
Registration date: 2009-10-06
Post by dlyz on Tue Oct 12, 2010 10:41 am
Ok, last night i swap the speaker cables L to R, by right, L shud be louder now, but when i measure with spl meter, R is still louder o.0"
Then i realise, maybe the fan from the pc which is near the R speaker influence the meter, so i check the spl with no sound from the speaker and indeed the R side got noise from pc =__="
I think the solution to my problem could me reposition the speaker a bit further from Right wall. Because my speaker is not dead centre in the room, the Left side is around 1.5m further compare to Right wall.
dlyz
Club Member
Club Member
Post by sph on Tue Oct 12, 2010 5:20 pm
If you have swapped speaker cables and the right side is still louder, then it is obvious that the amp is not at fault. Rather, it's the position of the speakers that's causing it (like you have finally deduced).
sph
