High-End Audio Cables: Myth or Fact?
Page 1 of 1 • Share •
I have read many differing views regarding the impact high end audio cables have on audio systems and would love to have some feedback on whether members believe there are any differences between inexpensive cables all the way up to exorbitantly priced audio cables.
Apparently, most perceived improvements to an audio system from usage of high end audio cables have been explained by listener bias and the "placebo effect".
More famously, James Randi a famous scientific skeptic has issued a $1 milllion dollar challenge to anyone who could prove their ability to prove they could distinguish between high end audio cables from ordinary cables but as yet no one has taken the test.
I personally upgraded my interconnects recently and swore there was a difference but perhaps I was merely trying too hard to justify the money spent?
gavstang- New Member
Number of posts: 4
Registration date: 2009-04-21
Re: High-End Audio Cables: Myth or Fact?
on this, i have no solid experience except between coax & optical
perhaps the application is more realistic with tube amps, or
those amps that generates much heat, like those huge monoblocks etc
from what i know, the source, amps, dacs, buffers, speakers,
caps in amps, jitter clocks, caps in xovers, caps in dacs,
that gaves lots of diff. interconnects? no, not really.
its more to 'sedapkan hati'?? hehe
just mho
just mho
azri- Frequent Contributor
Number of posts: 1036
Registration date: 2009-01-21
Truth is, Im very skeptical of touted expensive cables and inter connects. Especially speaker cables for AV systems when the cabling length is more than 50ft! What bloody difference does high quality cabling make when the signal has to travel so far?
Number of posts: 4
Dear gavstang,
I was a sceptic too but through time and many comparisons personally and on friends systems there is differences in sound when the inter connects are swapped.These differences are subtle and can be for the better or for worse.I personally would not spend huge amounts on these cables.I like others here have decided that DIY is the best way for interconnects and power cords ie. not designated hifi or audiophile.The best sound is still money in the pocket.
Regards,
Sivaguru
Regards,
Sivaguru
sivaguru- Frequent Contributor
Number of posts: 109
Registration date: 2009-03-09
Oh! An example is a good friend of mine has been using expensive silver speaker cables and recently swapped to a solid core copper cable after extensive listening tests.
I believe that there are differences between cables as the materials in each cable are made up differently. So the inductance and speed for transferring signals may vary. Some are good for bass but some are better for mid and higher frequencies. I personally noticed the differences when switching cables but definitely it doesn't mean that the more expensive cable will yield better sound. Sometimes you just need to match; a simple wire may do just nice to match your system. The best evaluation still is your ear, not the money.
hangleng- Regular
Number of posts: 84
Registration date: 2009-01-22
I love that dude! Best sound being money in the pocket!
Number of posts: 4
Any recommendations then on wires? Unfortunately I'm not much of a DIYer and have ZERO knowldege abt preparing my own wires.
Number of posts: 4
My speaker cables are the stock Bose ones. Simple stuff but RM150 or something like that. Felt like a rip-off but I got em anyway. CD to amp interconnects are the stock white and red plug with black cable type which came in the box with my Marantz SA7001KI player. Amp is a Marantz PM7200 and speakers are Bose 301s.
For further reading on audio voodoo skepticism google 'Douglas Self'. Without prejudice, there is a lot of voodoo floating around regarding amplification.
Furthermore, reviews having descriptions ('Warm', 'Smooth', 'Harsh',
etc.) which are immeasurable and/or unquantifiable further confuse customers. Until there is firm evidence to the contrary, I shall remain a skeptic but continue to enjoy music itself.
A good point i read someplace is that before you get to the actual cable-ing, you should first be getting clean power from your wall socket. If you are utilising one socket for various components, then it will not be clean power. And thereain lies the beginning of the problem - current source which isnt up to the mark.
I personally have had little experience with power cords and jumpers (i am sceptical) but have just started playing around with speaker cables & intercons. I find that the differences are subtle (what good is it buying high end speaker cables when the internal cables of your speakers are crap)
Remember, listeing to music is personal, and therefore there is no right or wrong - even if the difference is only "perceived" or as someone put it - a placebo.
Maybe the best thing to do is to get all your components right first, ie. you are happy with the system..... and then try to "tweek" it with cables at your own leisure.
Cheers
Cheers
dheensay- Frequent Contributor
Number of posts: 128
Registration date: 2009-01-20
good interconnects & speakers can make your system sound very transparent
you can feel that your room is much bigger than actual
M7- Club Member
Number of posts: 39
Registration date: 2009-05-05
speaker cable n p0wer cable...thin better or thick better?? coz market got sum thin cable expensive than thick 1....
royroy- Club Member
Number of posts: 45
Registration date: 2009-09-15
royroy wrote:speaker cable n p0wer cable...thin better or thick better?? coz market got sum thin cable expensive than thick 1....
Thin doesn't mean better...
...and Thick doesn't mean better as well.
It depends on the cable designs and technologies.
Number of posts: 1056
Registration date: 2009-01-19
Agreed with the first part..!
But I tweak no more when I am happy with what I hear..
Cheers
jazzy939- Frequent Contributor
Number of posts: 189
Registration date: 2009-04-19
scudracer wrote:My speaker cables are the stock Bose ones. Simple stuff but RM150 or something like that. Felt like a rip-off but I got em anyway. CD to amp interconnects are the stock white and red plug with black cable type which came in the box with my Marantz SA7001KI player. Amp is a Marantz PM7200 and speakers are Bose 301s.
Skeptisms and reading what other people write aside. Have you gone and ventured out to ACTUALLY trying some cables and see if u could hear the difference ? If you are keen, I am happy to oblidge and bring over a pair of "some hi-fi branded" interconnects and/or speaker cables to try in your system.
i wont tell you how much it costs, nor what brand are they. But they certainly look different than those black cables that come free with most equipment.
Game to try ?
Number of posts: 2665
Registration date: 2009-04-04
Source(s): Marantz
Amplification: Exposure
Speakers: Harbeth P3ESR
Similar topics» Audio Snimci
» Episode idea: High School!
» Penelope Cruz - High Quality Animated GIFs
» Rachel Nichols - High Quality Animated GIFs
» Michelle Trachtenberg - High Quality Animated GIFs
» HI5LOFT brings back Xindak!
» NAD C326BEE Amp (Used)
» Copper color PENNY V power cord
» SQUARECIRCLES - Immediately Seek Attention
» SEAS Excel woofer
» Musical Fidelity F22 (used)
» Philips CD104 (used)
» Amperex 6dj8/ECC88
