Automatic Voltage Regulator (AVR)
Post by BrAvO on Fri May 08, 2009 9:27 am
Hi all, after searching around Jalan Pasar for an AVR & went to the shop which Brad recommended too. I was told that almost 95% of the on shelf models are with 230V output with 3-5%+-. I am just wondering what is the most suitable output voltage to buy for our HiFi system usage? My equipments are with 220V & 230V input. What is the +- voltage a system can take in? scratch
I've called a distributor directly & he told me that their AVR is programmable to any output voltage you like so I would like to seek more info from all of you regarding of this matter before i proceed to get one from him.
BrAvO
Male Number of posts: 183
Registration date: 2009-02-07
Re: Automatic Voltage Regulator (AVR)
Post by Opera on Fri May 08, 2009 10:24 am
i have mine custom made to 220 +1 2%
Opera
Club Member
Club Member
Male Number of posts: 49
Registration date: 2009-01-20
Post by BrAvO on Fri May 08, 2009 11:28 am
Wow, plus 12% is a lot leh.... goes up to 246.4V output which is the same as my house output direct from wall.
BrAvO
Post by Johan on Fri May 08, 2009 12:42 pm
Every electrical equipment is designed to be used to a certain voltage supply according to the particular country. For example Malaysia's supply voltage is 240Vac +5% -10% which means the TNB supply voltage can vary between 216~252Vac actually this is in accordance to IEC standard for nominal supply voltage of 240Vac so we cannot say TNB supply isn't precise on the dot of 240Vac. Now European countries are standardising their supply voltage to 230Vac +10% -6%. So if you buy a product manufactured in Europe, or for the matter of fact from any other country, manufactured after year 2008 with the CE or EN logo at the back, with a voltage specification of 230Vac, it will work perfectly well in Malaysia. However, if its a 220Vac specification you definately need an AVR because the tolerance is +- 6% only. You can buy an AVR accordingly, probably a programmable is better.
Johan
Male Number of posts: 24
Registration date: 2009-02-05
Post by auronthas on Fri May 08, 2009 3:45 pm
For your information, Malaysia has fully adopted IEC standard voltage 230V +10% - 6% since 2006, you can refer more in details in MS IEC 60038: 2006 (correspondence to IEC 60038:2002). Hence the single-phase and three-phase voltages shall be 230V and 400V respectively in lieu of 240V and 415V.
Auronthas
_________________
Recent tracks played and scrobbled to Last.fm from Squeezebox 3
Easy Listening - Jazz - Classical - New Age
auronthas
Moderator
Moderator
Male Number of posts: 208
Registration date: 2009-01-19
Post by Opera on Fri May 08, 2009 10:46 pm
BrAvO wrote:Wow, plus 12% is a lot leh.... goes up to 246.4V output which is the same as my house output direct from wall.
typo error. 220 +- 2%
Opera
Club Member
Club Member
Post by BrAvO on Sat May 09, 2009 12:51 pm
Thanks everyone for your comment.
i think i will ask the supplier to set the output at 225V +-3% so It will work perfectly with any 220-230v input devices.
BrAvO
Post by hijau on Thu May 14, 2009 3:03 pm
Will it be any impact on sound by using "AVR" connected from wall power supply to a "Power Distributors"?
hijau
Club Member
Club Member
Male Number of posts: 48
Registration date: 2009-03-12
