Furutech Flux-50 & Flow-28 inline filters from Japan
Post by musiclinkav on Wed Mar 16, 2011 11:33 am
New arrival@ Musiclink! Introducing the new Flux-50 & Flow-28 inline Power Filters.
Model: Flux-50 in-line Power Filter. Usual Price@ $1399.00/each.  Promo Price  @ $1199.00/each.
The Furutech Flux-50 Inline Power Filter
AC-1501R EMI Noise Filter
Best Product of the 2010
High Fidelity Magazine Poland
High Fidelity Poland Best of 2010
Daytona 303 & Flux series review
搶先試聽 & Furutech Flux50
Audio Accessory 2010 WINTER 139
HiFi-Choice Collection UK 2010
STEREO 2010 October Flux-50 Filter
2010 AUTUMN vol.56
STEREO Oct 2010
Audio Accessory 2010 AUTUMN 138
STEREO SOUND 2010 Summer No.175
Flux Series review
Audio Accessory 2010 SUMMER 137
MJ 2010 May
MJ-2010 Apr
STEREO SOUND 2010 Spring No.174
STEREO 2010 March
AV Review 2010 March
Audio Accessory 2010 SPRING 136
Flux Series Review
Flux series Review 2009
AC Power Can Make or Break Your System
The audio you hear from your home entertainment system is essentially the incoming electricity itself, and the typically violent storms riding the AC line and its ground is very detrimental to the performance of your components.
The Flux-50 is a sophisticated, luxuriously made and finished inline power filtering unit that eliminates many common problems caused by contaminated electrical power lines. It protects against distortion caused by ground noise, voltage spikes and sags, high frequency power supply noise from other components in your own system, plus high frequency digital noise from processors and digital interconnects.
You’re never alone when you take your seat; the residential AC supply is shared with other apartments, homes, and businesses on the same utility transformer explaining why many enthusiasts notice their systems perform to a higher standard late at night and weekends.
The Flux-50 features the Innovations Award winning FI-50 power connector. They combine two “active” materials: Nano-sized ceramic particles and powdered carbon. Nylon and fiberglass are incorporated as well forming an extremely effective, mechanically and electrically nonresonant connector body that may just be the most sophisticated in the world. And it incorporates the AC-1501R EMI-filtering IEC connector.
The Flux-50 Inline AC Filter lowers noise on every component on which it’s used resulting in very natural and extremely fine resolution down and through the utterly silent noise floor. It improves soundstaging and image palpability and creates musical highs, an attractive, engaging midrange, tight and controlled bass, plus you’ll notice power and dynamics to spare.
•      Fitted with Furutech’s top-of-the-line high end performance Piezo Ceramic body rhodium plated α (Alpha) non-magnetic pure copper conductors FI-50R Connectors
•      GC-303+EMI Filter AC-1501R Rhodium plated α (Alpha) non-magnetic copper alloy conductors
•      Earth/Ground Jumper System (US Patent No.: 6,669,491 )
•      Patent pending metal cable clamp improves grip and reduces mechanically and electrically induced distortion plus patent-pending specially engineered pressure plate
•      Cable features an α (Alpha) conductor shield to protect against radiated noise.
•      RoHS compliant flexible PVC sheath improves vibration isolation
•      Special high-grade PE Insulation contributes to a reduction in capacitance.
•      Dimensions: Outer Diameter 50.7mm max., Overall Length 30cm Approx.
[size=20]Model: Flow-28 in-line Power Filter. Usual Price@ $650.00/each.  Promo Price  @ $599.00/each.
The Furutech Flow-28 Inline Power Filter
The Flow-28 is a sophisticated, luxuriously made and finished inline power filtering unit that eliminates many common problems caused by contaminated electrical power lines. It protects against distortion caused by ground noise, voltage spikes and sags, high frequency power supply noise from other components in your own system, plus high frequency digital noise from processors and digital interconnects.
The Flow-28 features the FI-28R IEC connector. And it incorporates the AC-1501R EMI-filtering IEC Inlet.
The Flow-28 Inline AC Filter lowers noise on every component on which it’s used resulting in very natural and extremely fine resolution down and through the utterly silent noise floor. It improves sound staging and image palpability and creates musical highs, an attractive, engaging midrange, tight and controlled bass, plus you’ll notice power and dynamics to spare.
•      The cover of the filtering unit combines two “active” materials: Nano-sized ceramic particles and powdered carbon. Nylon and fiberglass are incorporated as well forming an extremely effective, mechanically and electrically damped body.
•      For connection between power cables and power distributors or power cables and components. Eliminate and prevent radiated AC noise
•      Fitted with Furutech’s rhodium-plated α (Alpha) nonmagnetic FI-28R connector
•      AC-1501R EMI-filtering IEC, rhodium-plated α (Alpha) nonmagnetic copper alloy conductors
•      AC-1501R EMI filter features a parallel circuit with in-line coil and condenser, reducing noise at 1MHz by 10dB and at 10MHz by more than 30dB
•      Floating Field Damper (Earth/Ground Jumper System) US Patent No.: 6,669,491
•      Patent-pending metal cable clamp improves grip and reduces mechanically and electrically induced distortion
Cable Specifications:
•      Conductors:56-strand (Inner) and 29-strand (Outer) α (Alpha) OCC conductor・0.175mm x 3 cores
•      Insulation-1: Special irradiated PE (Red/Natural/Yellow) 3.45mm diameter
•      Insulation-2: irradiated PE surrounded by Teflon tape wrap, 3.6mm diameter
•      Inner Sheath: RoHS-compliant flexible PVC incorporating carbon particles
•      Shield: 0.12mm diameter α (Alpha) Conductor wire braid
•      Sheath: RoHS-compliant flexible PVC, 14.2mm diameter
•      Jacket: Vibration damping special Nylon Yarn Braid (Black)
•      α (Alpha) conductor shield for protection against radiated noise
•      RoHS-compliant flexible PVC sheath improves vibration isolation
•      Special high-grade PE Insulation contributes to reduced capacitance
•      Incorporating Furutech’s special passive GC-303 EMI filtering material
AC-1501R Specifications:
Outer cover- Cr Plated steel plate
Inner cover- Nylon glass fiber
Inner Box- Nylon glass fiber
Inner parts held by Piezo Epoxy
Rating: AC 115V/250V 15A 50/60Hz
[/size]
HURRY CHECK IT OUT SOON!
Reviews:
http://www.furutech.com/a2008/reviewc.asp?r1_no=79&r2_no=484
http://www.furutech.com/a2008/reviewc.asp?r1_no=26&r2_no=467
http://www.furutech.com/a2008/reviewc.asp?r1_no=40&r2_no=395
http://www.furutech.com/a2008/reviewc.asp?r1_no=103&r2_no=349
http://www.furutech.com/a2008/reviewc.asp?r1_no=53&r2_no=437
Available now@
MUSICLINK AV DISTRIBUTION
100 BEACH ROAD, #02-46-49
SHAW TOWER
SINGAPORE 189702
TEL: 65-62911106
MON-SAT: 12.30-8PM DAILY.
SUN: CLOSED
musiclinkav
Male Number of posts: 193
Registration date: 2009-11-29
