Scan-Speak R2604/8330 Ring Dome Tweeter
Post by allen6266 on Tue Apr 26, 2011 8:59 pm
Hi All,
Want to let go these pair of tweeter, bought brand new last year November 2010 for my DIY project. The tweeter is probably not fully run in yet.
Price: RM 800.00
Please PM, sms or call : 012-967 6677.
Specs:
Dual Ring Radiator Diaphragm (Patented)
Wave-guide center plug (Patented)
Extended frequency to above 40kHz
High Sensitivity - 92dB
Low Resonance Frequency - 630Hz.
Low Distortion
Double Magnet
Rear Chamber
Copper Clad Alu-wire
The dual magnet version of the ring dome tweeter provides extra magnetic energy to increase the sensitivity and to extend the frequency response to above 40kHz. The additional volume from the second magnet also increases the size of the chamber, lowering the resonance frequency. This tweeter is an excellent choice for any high end home or automotive system.
Nominal Impedance 4 ohm
DC Resistance (Re) 2.9 ohm
Effective Piston Area (Sd) 5.4 cm2
Voice Coil Diameter 25 mm
Voice Coil Height 2.2 mm
Air Gap Height 2.5 mm
Linear Coil Travel (peak) 0.2 mm
Net Weight 0.8 kg
Free Air Resonance 630 Hz
Sensitivity (2.83V/1m) 91.93 dB
Moving Mass incl. air (Md) 0.3 g
Long term max Power Handling 550 Watt
Overall diameter 104 mm
Cutout diameter 72 mm
Flange thickness 5 mm
Depth 54.6 mm
[You must be registered and logged in to see this image.]
allen6266
Club Member
Club Member
Male Number of posts: 33
Registration date: 2010-02-07
