Ci-Audio 24Bit/192Khz Dac + Psu from USA
Post by musiclinkav on Fri Apr 29, 2011 2:10 am
CI AUDIO USA
[You must be registered and logged in to see this image.]
USUAL PRICE@$1370.00/SET. PROMO PRICE@$1233.00/SET EXCLUDING GST
FREE Ambiance SILVER DC CORD + DIGITAL Coaxial CABLE + 6nines PowerCord WITH EVERY PURCHASE-WHILE STOCKS LAST!
MODEL: VDA2 DAC + VAC1 PSU
PRICE: UP:$1370.00 NOW: $1233.00/SET. Price exclude GST.
One of the Greatest Values in the DAC Marketplace!
The VDA-2 is Channel Island Audio's latest assault on exorbitantly priced high end DACs.  Featuring a revolutionary new circuit design and Burr Brown PCM1794 DACs, the VDA-2 has all the innovation and build quality you would expect from a Reference Caliber DAC at a price that's a lot easier to swallow. Our highest recommendation!           Perfect with the Wadia iTransport!
So, what's revolutionary about the VDA-2's design?
"Traditional DAC designs use brick-wall digital filters, usually followed by more analog filtering to reduce sampling noise, but cause signal degradation in the process. Another approach has been to use no filtering at all, but this adds noise to the analog signal.  Both of these designs have their strengths and weaknesses, but neither tends to be a good trade-off.  Our design uses only a mild 'slow roll-off' digital filter to tame the sampling noise, and no analog filtering. This architecture has reduced filtering artifacts compared to brick-wall types, and lower sampling noise than filterless types, resulting in a more 'analog' sound."
- Dusty Vawter, Channel Islands Audio
The signal path of the VDA-2 is very short and exceptionally clean, with digital signals being received by a low-jitter Crystal 24/192 input receiver, then fed to a Burr Brown PCM 1794 DAC.  The output stage is fully discrete (No Op-Amps), using one transistor per channel, ensuring excellent sound and robust output.
Features include switchable phase (0°/180°), dual inputs, support for both TOS-Link and Coaxial cables, signal 'lock' indicator, dual RCA outputs (or single XLR via optional VRX-1 cable to run into a balanced input), optional upgraded outboard power supply (VAC-1) and great sound!
Specifications:
Inputs: Toslink Optical, Coaxial SPDIF
Locking Frequencies: 44.1k-192k (Coaxial), 44.1k-96k (Toslink)
Frequency Response: 20Hz-20kHz +/- 0.1db
THD: <.02% 20Hz-20kHz
DAC Chipset: Burr Brown PCM 1794
Input Receiver: CS8416 24 bit/192k low-jitter
Output Level: 2.25vRMS (Single-ended), 4.5vRMS (Balanced)
Dimensions: 4.40'w x 2.65'h x 4.40'd
Warranty: 1 Year Parts & Labor
CIAUDIO - VAC-1 POWER SUPPLY
Upgrade the Performance of any CIAudio Product with the VAC-1 Outboard Power Supply!
The new CIA VAC-1 is the perfect upgrade for any CIAudio product! This upgrade power supply provides enormous improvements; improved bass definition, lower noise floor and wider dynamic range! The VAC-1 improves on the stock "wall wart" power supply by providing higher current power delivery and cleaner power, thanks to a custom made transformer and high current rectifier diodes. At this price the VAC-1 is simply a 'no-brainer!' Highly recommended!
“The VHP-1’s already impressive bass response became even more powerfully solid with the heavy-duty power supply (VAC-1). Not deeper, simply more physical. The VAC-1 went a long way towards making music a total-body experience. This was no small improvement, but it wasn’t the biggest change the VAC-1 wrought. That would be its increase in dynamic contrast.”-Wes Phillips, Stereophile, October 2005
Specs:
AC Input Voltage: 115VAC 60Hz
Output Voltage: 14VAC @ 1.44 Amps
Detachable IEC Power Cord: Yes
Accessories: IEC Type AC Cable, AC output Cable
Dimensions (HWD): 2.7"x4.5"x4.5"
READ THE GREAT REVIEWS:
http://www.audiophilia.com/hardware/rh5.htm
http://www.ciaudio.com/pdfs/reviews/TA_017.pdf
http://www.audioasylum.com/reviews/DAC-Processors/C-I-Audio/VDA-2/digital/126982.html
AWARDS:
Audition now @
Musiclink AV Distribution
100 Beach Road, #02-46-49
Shaw Tower
Singapore 189702
tel: 65-62911106
Mon-Sat: 12.30-8pm daily. Sun: Closed
musiclinkav
Male Number of posts: 157
Registration date: 2009-11-29
