Loud thump !
Loud thump !
Post by hasnul on Wed Jun 29, 2011 12:12 pm
Guys, my vintage sansui will let out a loud thump when turned on. That made the woofers moved quite strong. Should I be concerned ?
hasnul
Male Number of posts: 256
Registration date: 2009-01-22
Source(s): Hiface EVO + AudioGD DAC19, Thorens TD125 MKII + SME 3009 S2 Imp. tonearm
Amplification: Sansui AU-7500/ Primaluna Prologue 2 + Pipit 22L
Speakers: B&W DM4
Re: Loud thump !
Post by sph on Wed Jun 29, 2011 2:02 pm
I also experienced the same effect on my Cyrus 1. No damage to my speakers.
I was told it's quite common.
Apparently you can soften or eliminate the loud start up by putting a large value cap across the AC terminals or switch. This mod requires the expertise of an expert as it involves deadly AC voltage.
If you can live with the loud thump, then leave it as it is.
If this loud thump has been in existence since the beginning, then it shouldn't be an issue. But if it has only recently appeared, then you will need to have it checked.
sph
Male Number of posts: 101
Registration date: 2009-03-04
Re: Loud thump !
Post by hasnul on Thu Jun 30, 2011 9:54 am
Perhaps later I'll send for checkup. Thanks.
hasnul
Speakers: B&W DM4
Re: Loud thump !
Post by Wikin on Thu Jun 30, 2011 10:20 am
Hasnul,
Good solid state amplifier design employs circuitry to eliminate the thump. Either a soft start in the power supply or a DC monitoring system at the speaker outputs.
Sph,
I also used to own a Cyrus 1 and 2. While they don't have DC monitoring sytem at the output nor a soft start, during turn on I usually see a small movement on the woofer; that's about it. If it thumps I think perhaps the power caps are about to give way.
cheers.
Wikin
Male Number of posts: 276
Registration date: 2009-03-05
Source(s): PC Audio
Re: Loud thump !
Post by adrian4454 on Thu Jun 30, 2011 5:53 pm
? I thought this is quite common for vintage design. as most doesnt have relay in place yet. If last time dont have, but now u have it.. maybe the relay inside is permanently on already.
haha, my exposure amp thump and tack to my speaker every time I on and off it. It is infact an uncompromised sonic approach...less contact, more direct connection~~. though some of you may not agree~
adrian4454
Male Number of posts: 425
Registration date: 2009-02-03
Re: Loud thump !
Post by Wikin on Fri Jul 01, 2011 10:12 am
That's precisely what smart marketing does... it cleverly covers downfall of a design "kononnya" for sound improvement... Laughing In actual fact they are cost cutting by removing vital items in the amplifier.
Switch on thump can be solved by installing an output relay with delay on, switch off tack can be solved by installing a 240V rated X capacitor on the power switch.
cheers.
Wikin
Source(s): PC Audio
Re: Loud thump !
Post by adrian4454 on Fri Jul 01, 2011 2:04 pm
Hmm.. I dont think Exposure 2010s2 will do that just to save around RM10...
Anyway, maybe you are correct~
adrian4454
Re: Loud thump !
Post by Wikin on Fri Jul 01, 2011 3:32 pm
adrian4454 wrote:Hmm.. I dont think Exposure 2010s2 will do that just to save around RM10...~
RM10 is from our consumer's point of view...
From manufacturer's POV it's :
it's RM10 x XXX units = $$$$$ savings for the model ....
cheers.
Wikin
Source(s): PC Audio
