[SOLD] Sony TA-E2000ESD Digital Processing Control Amplifier (Preamplifier), Sony TA-N330ES Power Amplifier, Sony TA-N220 Power Amplifier (All Used) [SOLD]
Post by Razzd on Wed Jun 29, 2011 2:17 pm
SOLD to a very nice gentleman. I hope you enjoy the amps as much as I have enjoyed listening to it for so many years...Note: You will need to log in HiFi4sale.net in order to view the pictures I've posted, else you will not be able to see the images of the actual product.
I have for sale as a pair the below:
Sony TA-E2000ESD Digital Processing Control Amplifier (Pre-amplifier) & Sony TA-N330ES 2-Channel (Bridgeable) Power Amplifier:
  • Sony's renowned Elevated Series (ES)
  • Ultra high quality internal components
  • 100% perfect working condition
  • Very Good to Excellent Condition (for its age); actual pictures taken on the day this ad was posted 29/06/11
  • Comes with side laminated wood panels
  • Both Made In Japan
  • Contact: SMS Alf 012 390 5071 or email srazzd@gmail.com
  • Asking: RM 1,500 for the pair/set (nego) RM 1,200 for the pair/set SOLD
  • Condition: To be sold as a pair/set, will provide delivery if within PJ/Subang/Shah Alam area
  • Reason for sale: Upgraded to latest 7.2 AV Network Receiver
  • Note on the actual images of the components: Pictures taken were not Photoshopped and/or retouched in any way, just cropped to size & sharpened a little
I have also for sale separately or together with the above, Sony TA-N220 4-Channel (Bridgeable) Power Amplifier (pictures below):
  • 100% working condition
  • Very Good to Excellent Condition (for its age); actual pictures taken on day this was posted 29/06/11
  • Made In Japan
  • Asking: RM 500 SOLD
  • If all 3 Pre-amp/Power amps taken together will give a bundle price package
Sony TA-E2000ESD Digital Processing Control Amplifier (Pre-amplifier):
Specifications/Details:
Made In Japan
Built-in Dolby Pro-Logic Surround system for a movie theater experience.
Dolby Pro-Logic with 3 additional modes: "Phantom", for a 4 speaker set up; "3 Channel. Logic", for use when rear speakers aren't needed or convenient; and "Wide", which is designed to make a small room sound more theatre-like.
The TA-E2000ESD also has Digital Signal Processing (DSP), which is configured primarily for creating a concert hall experience. The DSP has 10 factory defined settings.
In addition, up to 10 user defined sound fields can be stored in memory by choosing various surround, parametric equalizer, and adjustable reverb settings.
Advanced signal processing options, every aspect of the sound field is completely adjustable!
Able to create a wide variety of audio environments with the highly flexible TA-E2000ESD
The parametric equalizer can adjust each of the 5 channels independently!
Comes with Original Sony Programmable Remote Commander RM-P2000 & Original User Manual
Sony TA-N330ES Power Amplifier:
Specifications:
Made In Japan
System: Super Legato Linear, Pure Complementary SEPP Power amplifier with massive Toroidal Transformer & massive Capacitors
Channels: Two (Stereo) or Bridgeable (Mono)
Power output (per channel): 110 watts into 8 ohms/ 150 watts into 4 ohms
Bridgeable to mono: 300 watts into 8 ohms (THD 0.05%)
Frequency response: 20 to 20,000Hz
Total harmonic distortion (THD): 0.01%-0.05%
Damping factor: 100
Dimensions: 430 x 150 x 365mm/ 467 x 150 x 365mm (with side wood panels)
Weight: 12.2kg
Power consumption/voltage: 310 watts/220-240 volts
Sony TA-N220 4-Channel Power Amplifier:
Made In Japan
The Sony TA-N220 4-channel power amplifier can be used as a 2/3/4 channel separate power amplifier & features a BTL (Balanced Transformerless) bridgeable channel system which produces a powerful sound. You can use this versatile power amplifier to compliment a control processing amplifier or pre-amplifier to drive your surround speakers, passive subwoofer and or Zone 2/3 speakers in another area.
Channels: 2-channel (both bridgeable), 3-channel (1 bridgeable) , or 4-channel output
Power output (per channel): 50 watts into 6 ohms
Power output (BTL): 100 watts into 8 ohms
Total harmonic distortion (THD): 0.12% at rated power
Dimensions: 470 x 135 x 370mm
Weight: 10.0kg
Power consumption/voltage: 280 watts/220-240 volts
All three available as a bundle package:
  • Sony TA-E2000ESD Digital Control Processing Amplifier
  • Sony TA-N330ES 2-Channel (Bridgeable) Power Amplifier
  • Sony TA-N220 4-Channel (Bridgeable) Power Amplifier
This setup will be ideal for those of you looking for an excellent 2nd system to drive your multi-channel speakers or use the power amplifiers to drive your Zone 2/3.
Last edited by Razzd on Mon Mar 12, 2012 6:04 pm; edited 20 times in total (Reason for editing : Added details/specifications/picture updates)
Razzd
Male Number of posts: 14
Registration date: 2011-02-11
