Musical Fidelity V-Link Review
Hi-Fi 4 Sale - Malaysia / International Audio Marketplace & Forum | www.hifi4sale.net :: Discussion Forum & Knowledge Base :: Equipment Reviews
Page 1 of 1 • Share •
Review coming up soon.
elhefe- Moderator
Number of posts: 827
Registration date: 2010-02-13
Source(s): ClearAudio TT, MF M1 (CDT, DAC, CLiC, HPA, ViNL), SONY MD, ONKYO tape deck, Wadia 170i
Amplification: MF M6i Integrated Amp, M1 PWR Power Amp
Speakers: ProAc Response D18
Re: Musical Fidelity V-Link Review
OK. Overdue review. Was travelling and sick for the past week.
So, MF distributor offered me to review this unit as it has just arrived in his stock 2 weeks back. Yes, the unit is actually on the market for a while now but just officially brought into Malaysia.
So what does it do? It basically offer a solution for those USB 48kHz/16 bit limited bandwidth input on any existing DAC, including my M1 DAC.
Its commercial name: 24 BIT 96 kHz ASYCHRONOUS USB TO S/PDIF CONVERTER WITH COAX AND OPTICAL OUTPUT
Connect the unit to yr PC/laptop USB port (using A/B USB cable), it then upsamples it to 96kHz and feed this signal constantly to your DAC via optical or coaxial. Just as long as your DAC coax or optical can receive 96kHz signal and above, you are good to go.
My M1 DAC detects the 96kHz easily as shown in the picture. Then the DAC upsamples it further to 192kHz. Not sure whether this repetitive upsampling is actually good or not. Hehehehe.
So my findings:
Build
As it comes under MF's V series, the built is as expected to be lightweight, mainly to make it affordable. But nothing to complain about. It is however bigger in size than I expected. Light but sturdy with all the connections to be solidly placed and does not wiggle when you try to push in that coax cable in. You have to push your coax cable all the way in before it can output the signal.
The 'Lock' and 'Power' LED however is a tad too bright as you can see above in comparison the M1 DAC LEDs.
Power
No external power supply is required. It takes power from your PC/laptop via the USB cable.
The Session
I did not do any serious comparison apart from an A/B comparison between the following:
1. Laptop connected directly to M1 DAC USB input
2. Laptop connected to VLink and to M1 DAC via coax
Tracks used:
1. La Mer - Kevin Kline
2. Time to Say Goodbye -Andrea Bocelli
3. My Hero - Foo Fighters
First impression of Vlink - Bold and bass heavy. It sorts off amplified the overall digital file.
Volume wise, there is definitely a different between straight USB connection than via the Vlink. At the same volume level on the amp, the Vlink produces a louder sound.
Details however, I cant seem to hear much difference between the two connections above. Maybe because both are upsampled to 192kHz anyway.
I would however give credit to Vlink for creating a livelier music experience. It does inject some air into the digital music. It might just be my mood that night but the La Mer definitely sounded more emotional and the vocals by Kevin Kline sounded so near to me.
Verdict
For the given price, it is to me a well worth upgrading route for PC based music lover with limited bandwidth USB input on their DACs. Or even for DAC without USB input.
For me, I am not a hardcore PC-based music lover. I do stream my music across the house using AE, but I dont really measure their SQ. As long as there is music in the background I am OK.
So, its your pick.
So my findings:
Build
Power
The Session
Tracks used:
Verdict
So, its your pick.
elhefe- Moderator
May I ask if the difference between the V-Link and M1 is appreciable(noticeably apparent) or subtle at best? I noticed the V-link is the older version and not the latest V-Link II. Is your M1 the old or current version (with the asynchronous USB input)?
Thanks.
Thanks.
ryder- Frequent Contributor
Number of posts: 649
Registration date: 2009-02-06
The overall presentation by V-link is louder and bass heavy compared to direct USB connection to M1, somehow amplified. It presents the similar clarity and details as M1 DAC via USB. However, the livelier soundstage from the V-Link is very noticeable.
Bare in mind...this is comparison between non-async USB connection and Vlink....and not with a CD player.
Yup...when I tested this unit, the V-Link II was not out yet.
_________________
elhefe- Moderator
Thanks for the information. Much appreciated. The V-link certainly comes close to the MDAC's performance at a much lower price.
Cheers.
Cheers.
Similar topics» Fran ... Contrast review of Judit with review of Maite.
» Obitsu 11cm review
» 5.11 All Hazards Prime Backpack, Write-up review
» link for bakugan dimensions
» Buat lah link ke 3gp melayu
» Furutech RTP-6N power distributor(used)
» Acoustic Zen Tsunami power cord (New)
» MiT Zcord ll powercord(used)
» Tara Labs Prime M1 Interconnects (New)
» PS audio prelude sc powercord (used)
» NBS signiture ll power cord(used)
» Denon SCM51 Bookshelf Speaker (Used)
» Teac A-R600 Integrated Amplifier (Used)
» Proton Integrated Amplifier AM-3 (Used)
