AVANCE Floorstanding Speaker (sold)
Made In Denmark
The history of AVANCE Loudspeakers takes its beginning with the son of a radio designer and electronics retailer, Mr. Poul Rossing, who is today considered as one of the true founders and pioneers of Denmark's hi-fi industry.
Poul Rossing states that: "We started AVANCE with a simple idea to make the highest quality speakers at the best price possible so more people can enjoy them around the world – and we want to continue this philosophy" – you know that it is actually true...
Developing attractively priced high quality loudspeakers is not an easy task and cannot be simplified and expressed with one particular design philosophy. At AVANCE in Holbaek, Denmark Poul Rossing combines all aspects of physics and mathematics with computer aided design and measurements and intense listening tests. They even implement design input from at team of highly trained, independent audio reviewers.
Still today all AVANCE loudspeakers feature heavy and rigid enclosures and top quality drive units that always bring AVANCE among the best in tests. The cabinets are manufactured from high density fibreboard and are all extendedly braced and assembled using non-hardening glues. Inside you'll find high quality crossovers of first, second, third and fourth-order networks dependent on the drive units used and the particular needs for target sensitivity, sound dispersion and frequency response.
AVANCE Omega series was appreciated as “Classical AV Series” and it led stably the best-selling champion during the 90’s in last 20th.
丹麦进口 皇冠 AVANCE OMEGA 30 高档发烧 落地音箱hifi
丹麥avance omega 30 TWEETER
丹麥製 vifa TC25TG05 發燒 高音單體
Tymphany是世界著名音響集團之一,有80多年的歷史。目前PEERLESS與VIFA是其旗下兩家主要品牌。。
TC25TG05是VIFA頗富盛名的高音單體,為眾多著名音箱所使用。本賣場這對單體即是拆自著名丹麥avance發燒音箱,高音延伸範圍廣,原音箱利用此特性,直接搭雙8吋低音單體做成落地喇叭。
6歐抗阻/總直徑104MM/開孔80到85MM/螺孔對徑94MM/總高30MM
丹麥avance omega 30 MID BASS Woofer
德國製 HKM/Westra KW-200-1398 8吋 低音單體
Specification
frequency range : 40-20000 Hz (3dB)
Sensitivity: 90dB
Norminal Impedance: 4ohms
Nominal power: 120Watt
Musical power: 200Watt
Speaker Driver :
Vifa (Denmark)- Soft Dome tweeter TC25TG05
Westra (Germany)- low-range (Westra KW-200-1398 8-inch)
Dimensions: 26.5 x 29,5 x 101 [cm]
Weight : 19kg / per Unit
- Number of posts : 2967
» Atc 20t Floorstanding Speaker (SOLD)
» Floorstanding Speaker sold
» TDL RTL-3 Floorstanding Speaker (sold)
» PMC OB1 Floorstanding Speaker [SOLD]
