Trouble Shooting BSR C114R Turntable
Page 1 of 1 • Share •
But i test a turntable when i attached to my Marantz 1090 amp and still running good. The problem is, when i add to my amp, the left channel is very clear sound but the right channel is very slow and sometimes has a loud bass when i touch the RCA jack. Anyone here can advise me what should i do before i send to speciallist to check it out.
Please brief me...
Porex- Club Member
Number of posts: 37
Registration date: 2010-11-27
Re: Trouble Shooting BSR C114R Turntable
Porex...
Try unlocking the RCA connectors to check the soldering of the cables, check the cables for loose connection from end to end.
Most likely is the RCA jack's , dry joint or oxidation of the RCA connectors, had a similar issue with my first TT. If you are handy with a soldering iron then its a simple cut and replace.If you are not get a repairmen ( your regular ) to replace the RCA connectors, get him to do a once over as well. Changing the cables ( output ) would be an option as well, with age it deteriotes.
Get it up and running, spin a few records, after which you make plans on your next step.
Enjoy the new found interest.
cheers
cheers
wingman- Frequent Contributor
Number of posts: 701
Registration date: 2009-08-10
Hello Mr. Wing....
I'm so proud of you regarding your knowledge and sharing about electronics experience to my old turntable as i said, since i receive your post, I'm try to do myself operates as u said, but i have take a little bit times to check a wire because the wire is too small and tiny than a network telephone cable, I try soldering and change RCA connectors but at first time not well and the second time it works!! my turntable running very good without noise or distortion sounds, and i am very enjoying the really original sound from my iron maiden LP, and i find my new interest as you said......
Mr. Wing...Thanks and Regards....
Porex- Club Member
Number of posts: 37
Hi...
No Problem and glad to be of help. As I said enjoy your new found interest.
Keeping me out, there are quite a handfull of forummers who are very well versed on TT setup and anything related to Hifi to which I am still picking up the know how's.
Keep browsing and you will come across quite a handfull of informative
, technical
and tensed
threads. End off the day enjoy
the equipment / music that you have invested in.
cheers
cheers
Similar topics» Ohio School Shooting
» Looking for Trouble?
» having trouble upload'n pics
» TIP: Trouble-Shooting guides at Cox International
» Quick troubleshooting guide for Dynaco tube amps
» Used van den hul interconnect
» Tannoy M20 Gold Mk 2 ( Used )
» The Chord company interconnect (New)
» Acoustic Zen MC² = Zen digital cable (New)
» Acoustic Zen Matrix Reference II interconnects (New)
» Furutech RTP-6N power distributor(used)
» Acoustic Zen Tsunami power cord (New)
» MiT Zcord ll powercord(used)
» Tara Labs Prime M1 Interconnects (New)
