Amplifier hum
Page 1 of 1 • Share •
Amplifier hum
Gentlemen,
My amp hums when my wife uses a hairdryer from the same room and my daughters room. It immediately stops when hairdryer switch off. My house is installed with 3 phase wiring. The amp even hums when on standby. Does that mean the 2 rooms are sharing the same phase? Will the humming have any long term adverse effect on the equipment and what can i do to prevent it?
Thanking all of you in advance.
ongaaron- Frequent Contributor
Number of posts: 209
Registration date: 2009-01-21
Source(s): Tri cd player
Amplification: Krell
Speakers: Proac
Re: Amplifier hum
Maybe this could help:
http://www.russandrews.com/product.asp?lookup=1®ion=UK¤cy=GBP&pf_id=1403&customer_id=PAA1059015312823NFCBXQIDTIBWSSCY
_________________
elhefe- Moderator
Number of posts: 827
Registration date: 2010-02-13
Source(s): ClearAudio TT, MF M1 (CDT, DAC, CLiC, HPA, ViNL), SONY MD, ONKYO tape deck, Wadia 170i
Amplification: MF M6i Integrated Amp, M1 PWR Power Amp
Speakers: ProAc Response D18
Re: Amplifier hum
wah.. u can hear the hum while the hair dryer was blowing away?
I believe there is some noises from the Life or Neutral that is being bled to the ground.
What amp you are using? and do u have any basic electric noise filter?
Lifting the ground at the amp could sometimes solve this problem; but it is not something u should do if your amp is running on 3 pin plug from the beginning.
Number of posts: 425
Registration date: 2009-02-03
Re: Amplifier hum
Ya..i also read that lifting the ground is not advisable. Krell with a 750va transformer and no basic noise filter. It is plug straight to a US pin wall socket.
Speakers: Proac
Re: Amplifier hum
oh ok. a good quality amp. So cant be the transformer acting up.
You may need to do some troubleshooting by isolating all possible cause that lead to this..
Since you can simulate the condition by switching on the hair dryer.
I suggest you to unplug interconnect to the amp 1 pair at a time and on the hair dryer to identify where it is coming from.. sometime, it is not from the amp. can be the source.
Good luck.
Good luck.
Re: Amplifier hum
Tried one pair at a time. Also unhooked the speaker wires. Atlast, disconnect everything except the power cord. Amp on standby. Problem persist.
Speakers: Proac
Re: Amplifier hum
I think it's the interference (electrical noise due to poor suppression)coming from the hairdryer motor into the mains and picked up by your amp.
CT-Boy- Frequent Contributor
Number of posts: 219
Registration date: 2010-01-24
Source(s): Technics SL-5
Amplification: Rotel RA-820
Speakers: Gale 3030
Re: Amplifier hum
Yeah, i kind of agree with CT-Boy.
Have you considered asking her to shave her head bald so eleminating the need to....
Sorry! So so sorry!! Could not let that one go... In a sstrnge mood past few days. Probably not helping you much.
Would an isolation transformer help.... but for krell power, it would be kind of mahal...
Bal...
Bal...
bal- Frequent Contributor
Number of posts: 283
Registration date: 2009-03-06
Source(s): Esound cdp, mac book pro with decibel thro m2 Tech and Buffalo II dac
Amplification: home made pre, vincent 330 power
Speakers: maggie MMG, Vienna acustics Haydn, Def tech BP6
Re: Amplifier hum
Is your amp and other rig earthed?
Are you sure your home electrical earth is in ideal or perfect order?
Home earth system is often ignored thinking it last forever the lifetime of the home. If unsure, please employ a competent electrical contractor to check and rectify your home earthing system, not only good for hifi but other safety aspects.
The home earth system can rot away or go missing (due to remodelling the home) in 10 years. I've heard of horror stories because of this especially during lightning strikes, bye bye TV, bye bye some other expensive home appliances.
cmboy- Frequent Contributor
Number of posts: 1163
Registration date: 2009-03-11
Re: Amplifier hum
Gentlemen, my apologies. I think i got the term humming misleading. just took the same hairdryer to the dealer and his demo amp suffered the same problem. It sounds more like a light rattle and according to him, it is due to the hairdryer sucking the current from the common phase. My hifi outlet is definitely sharing the same line with the hairdryers outlet. He suggested a dedicated line direct from the fuse box.
Speakers: Proac
Re: Amplifier hum
Perhaps you can just interrupt your listening session for a few minutes while the women of the house do their hair-drying. During the few minutes you can get a cold beer from the fridge and get comfy, ready to continue the listening session.
That will keep things simple without having to do any major re-wiring and the savings could be used for other things (hifi accessories etc.)
sph- Frequent Contributor
Number of posts: 101
Registration date: 2009-03-04
Re: Amplifier hum
hello Ongaaron,
Refer back to ur first post again, you also mention it hum/rattle by itself even without the hairdyer power on.
So I think there are 2 isolated problem here. 1. of course is the noise from the hair dryer. 2. Noise from your amp.
So it means without the speaker being connected, u still hear noise from your amp?
If it is a decade old amp, probably the transformer is acting up, where the bolt tighten it to the chassis comes a bit loose. Well you of course can Macgyver yourself, if u really know what to do about it. Do note, that this cannot be over tighten, as it will damage the transformer. also, chance is this may not solve your problem. it maybe the transformer winding itself that already loosen up. If you can't bear with it, u need to have it rectified by the authorise dealer. Also, the source of such hum/rattle may not be coming from the transformer, but other panel or PCB in the amp being loose.
Mean time, your hairdyer.. better not use it or buy her a new one. it must have generated rather unusual electric flux or arc. Otherwise, you should not hear anything from the amp or speaker eventhough a hairdyer is attached on the same power outlet.. not for your Krell.
Haha, we just can't let you go over this issue, didn't we?
Re: Amplifier hum
Adrian, what i meant was when amp on standby, when hairdryer is on , there is a rattle/hum.When hairdryer off, it is silent when on standby and when switch on.
Speakers: Proac
Re: Amplifier hum
This humming sound during standby, is it coming from the amp? Not from the speakers, right?
Speakers: Gale 3030
Re: Amplifier hum
Yes, from amp only
Speakers: Proac
Similar topics» Prototype 125 watt monoblock tube amplifier KIT
» amplifier for 6 speakers
» NAD C 375BEE Integrated Amplifier
» Voltage Amplifier Tube on VTA
» TAS rates the Dynaco ST-70 as the "#1 Most Significant Amplifier of All time"
» Arcam DV 88 DVD/CD player
» Denon AVR-1508 AV Receiver
» Pioneer A-9 [80s] used
» Usher Audio S520 speaker
» Harman Kardon AVR-80 [SOLD]
» PrimaLuna Prologue 2 Tube Integrated Amp (Used)
