NAD 214 Bridged Monoblock Power Amplifier (sold)
Bridged monophonic mode :
Continuous power [ min RMS per channel 20Hz - 20kHz less than rated distortion ]:
- 240W RMS @ 8 Ohm (normal)
- 360W at 8 ohms (Dynamic headroom )+1.8dB
The NAD 214 is designed with the capability to drive all types of musical signals effortlessly into the even most unreasonable of loudspeaker loads, down to below 1ohm.
This is achieved by implementing a high output current amplifier powered from a "stiff" power supply. The 214 couples a bank of reservoir capacitors to a large toroidal transformer. Using a bank of capacitors rather than a single pair is both technically superior and more economical
The special Holmgren toroidal transformer has less hum and magnetic leakage than conventional toroidal transformers but retains the usual benefits of high efficiency and high power to weight ratio. The entire "front-end" is fed from a separate low-noise, high voltage, discrete component regulated power supply which effectively isolates the amplifier from power ripple and noise. Careful design incorporating sensible grounding results in an amplifier with an exceptionally clean, noise free output signal.
Dimensions
- [ W x H x D ] : 435 x 128 x 383mm
- Weight : 11.3kg X 2 unit
Price : RMsold for 2 Unit Power Amplifier (Pair)
- Number of posts : 2967
» VTL MB 450 signature monoblock power amplifier (Used)SOLD
» Marantz MA-500 Monoblock Power Amplifier (Used) SOLD
» Sold - Bryston 7B SST monoblock power amplifier (Used)
» Emotiva XPA-100 Monoblock Power Amplifier [SOLD]
» KRELL MDA-300 Monoblock Power Amplifier(sold)
