Furutech e-TP609 AC Power Filter Distributor (New)
2 posters
Furutech 100% GENUINE
•Features Axial Locking System
•GC-303 EMI-Absorbent Internal Coating
•Chassis CNC machined from solid block aluminum and
equipped with mounting spikes
Rating
•Outputs: 6 Outlets
•Input: 15A/125V..10A/250V Furutech's FI-09(R) Rhodium-Plated Pure copper IEC Inlet
Features
•Covered with special Vibration Dampener Coating to achieve the best resonance damping.
•Dimensions: 266mm (W) x 130mm (D) x 56mm (H)
•Net Weight: 2.85Kgs
•Rated: 15A/125V..10A/250V
The e-TP609 is a sophisticated, luxuriously made single-chassis power distributor that eliminates many common problems found in audio and video components caused by massively contaminated electrical power lines.
The AC waveform becomes severely distorted by ground noise, voltage spikes and sags, high frequency power supply noise from other components in your own system, plus radiated high frequency digital noise from processors and digital interconnects. There are also distortion products at the top and bottom of the AC waveform created by switch-mode power supplies in electronic devices on the same circuit. Additionally, you’re never alone; your residential AC mains supply is shared with other apartments, homes, and businesses on the same utility transformer. That’s why many audio and video enthusiasts notice their systems are more enjoyable late at night or on weekends!
Formula GC-303
GC-303 is a special material Furutech bonds to the interior bottom-plate of the chassis that absorbs EMI (Electromagnetic Interference) generated by the internal fittings of the unit. The e-TP 609 uses no filtering besides Formula GC-303 so AC resistance is kept to a minimum, allowing a more resolving, powerful, dynamic, and colorful performance from your components.
Condition : NEW
Ask For : RM 5300.00
Contact : pls call/sms/whatsapp Alex at 012-3023330 for more info. Thanks.
Location : can pickup in Kepong / Selayang / Bandar Utama,Damansara PJ. COD
Postagecost : Include
Rating
•Outputs: 6 Outlets
Features
Formula GC-303
Condition : NEW
Alex,Leng- Dealer\Reseller\Trader\Service Provider
- Number of posts : 1223
Registration date : 2011-09-08
Amplification: Denon AVC-A1HD , Naim SuperUniti
Speakers: Chario , Morel Supremo , MB Quart , Mordaunt Short , REL R505 Sub , Pioneer.
Re: Furutech e-TP609 AC Power Filter Distributor (New)
Chinese New Year Sale Promotion
!!!!!!!!!Bump..
!!!!!!!!!Bump..
!!!!!!!!!Bump..
!!!!!!!!Bump..
!!!!!!!!!Bump..
!!!!!!!!!Bump..
!!!!!!!!!Bump..
!!!!!!!!!Bump..
!!!!!!!!!Bump..
Furutech
Greeting from Malaysia
haji-K- Frequent Contributor
- Number of posts : 102
Registration date : 2013-07-25
!!!!!!!!!Bump..
!!!!!!!!!Bump...
!!!!!!!!!Bump..
!!!!!!!!!Bump..
!!!!!!!!Bump......
CNY Bump..!!!!
!!!!!!!!!Bump..
!!!!!!!!!Bump....
!!!!!!!!!Bump..
!!!!!!!!!Bump..
» Furutech E-TP609 Ac Power Distributor
» Furutech e-TP609 power distributor (used)
» Furutech e-TP609 AC Power Distributor
» Furutech e-TP609 NCF High End Performance NCF Power Distributor (New)
