Gyrotension Vega Isolator
[size=4pt]Gyrotension Vega -Small handle up to max 12kg ($500 for set of 4)
BIG, Handle up to max 18kg per pc ($600 for set of 4)
[/size]
I realize with the Gyro, I am able to turn my volume up by 4 more dbs compared to previously when I was using the ceraballs. This clearly shows how effective the Gyro is isolating vibrations from the floor, thereby affecting the
the noise in t he background from the speakers. However, this only happen when I adjusted the tension correctly
by placing more rings in the spikes closer to the transformer of the amp while cutting back on the rings for the footer
furthest away for the heaviest (transformer)
Once again great product.. I am poisoned by the sound of the Rockna DAC. Been thinking of it since yesterday.
My Findings with the Gyro
Darker Background. Instrumental vocal has more presence.Insturment details has more weight
Bass was deeper.PRAT improved due to less "interference " to the tubes.
Gyrotension Vega two-stage floating isolator . It not just control horizontal- vertical vibration.
It control rotational vibration 360 degree base on the great design idea of the Gyro.
Music is more organic and bass are in control. Even Hiend equipments users reported improvement
when using this tweak. So in mid range hi-fi gear , it will really benefits too.
Customer setup - SUNAUDIO ON GYROTENSION VEGA
Customer purchase both the small and big Gyrotension Vega for both Digital and Analogue gear. The Gyrotension
has proven yet again , it's offer a more analogue sound, throw in deeper sound stage on a full gyro setup.
it's not by coincidence , customer goes full swing and put all his equipments on Gyrotension. Further tweak to the Gyro tension adjustment is needed to fully optimize its performance.
Impressions from customer
Oppo BR player - Sharper and brighter
On Phono is good too.
Low volume listening, quiet and background Blacken
Avantgarde speaker on Gyrotension - For speaker ,we strongly recommend 6 units per side
Bass to Mid to Highs all a notch up.
Soundstage open up with increased depth.
Customer Full System setup with Gyrotension Isolator
User 1 Comment
The CD player seemed to be even more analogue.Vocal more smooth. Instruments more
distinct and detailed.Background darker.More Hiend Sounding. Very shiok !
New local User 2 comment
In my system I just try the Gyrotension footer on my tube CD player.The sound stage
widens and imaging improves.Especially for jazz recording.I can locate each player / instrument easily.While listening to the album Time Out by Dave Brubeck Quartet, I was able to pinpoint the player not just laterally but also their depth in relation to one another.Just to be sure, I confirm my impression by checking the photos of the recording session in the CD album insert and I was right regarding the position of the players.
New review from TNT audio. for Garrard 401 turntable
Vega implements floating type vibration isolators radial symmetry silicone ring structure. They have adjustable tension setting by the number of rings and uses double vibration isolation design by silicone rings and 3-point support ceramic balls. Radial symmetry ring design absorbs, diffuses and dissipates all kinds of vibrations more effectively.
Max wt
12kg for the small version per unit (For preamplifier, CD player, music server ) - $500 FOR 4PCS , 3 FOR $375
18kg for the large version per unit (Great for speaker, Turntable, power amplifier) - $600 FOR 4PCS , 3 FOR $450
CD player and Music Server resting on Small Gyrotension Vega.
3 customers were at my shop yesterday , comparing both with and without the Isolator.
Before the Isolator - The music flow were not as fluid, the sound staging were narrower.
When the Isolator is at work - Strings sound more crisp and darker background, The position of each instruments easily located, plucking of the string instruments are more vivid.
GML Speaker on the Big Gyrotension Vaga Isolator
Hi End System uses Vega - Solution amp with Magico speaker
[size=4pt]Payment by Paypal
[You must be registered and logged in to see this link.][/size]
Brands we carry
ATC speaker & amplifier (100% UK Make)
Care Orchestra Designer Speaker (Italy)
Duelund cables and capacitors (Denmark)
ETI, KLEI RCA (Aus)
Fostex speaker (Japan),
German Hiend Cable (Germany)
Gyrotension Vega Isolator ( Korea)
GML Speaker (Singapore)
Line magnetic tube amplifier (China)
Neotech cable (Taiwan)
Mundorf capacitors and cables (Germany)
Mytek Brooklyn ( USA)
Psvane Tube ( China)
Rockna Wave Dream DAC , Audio Byte Hydra Z Bridge , ZPM
Full Music Tube ( China)
Custom Full Range Speaker boxes
TAD 15" Horn Box
Blk34 Upper Cross St
#02-152
Robert 65 92383607
[/size]
User 1 Comment
Max wt
Brands we carry
ETI, KLEI RCA (Aus)
TAD 15" Horn Box
#02-152
Robert 65 92383607
Artaudio- New Member
- Number of posts : 12
Registration date : 2015-04-03
» GYROTENSION VEGA iSOLATOR
» Gyrotension Vega
» AURALiC Vega DAC
» AURALiC Vega DAC
» Suzanne Vega USA LPs
» Gyrotension Vega
» AURALiC Vega DAC
» AURALiC Vega DAC
