Klipsch Tangent T4000 3-Way Horn Floorstand Speaker (Sold)
Klipsch Tangent T4000 3-Way Horn Floorstand Speaker (Sold) Empty Klipsch Tangent T4000 3-Way Horn Floorstand Speaker (Sold)
Post by HiFiLab Fri Jul 19, 2013 1:47 pm
Klipsch Tangent T4000 3-Way Horn Floorstand Speaker (Sold) 20130726
Klipsch Tangent T4000 3-Way Horn Floorstand Speaker (Sold) 20130728
Klipsch Tangent T4000 3-Way Horn Floorstand Speaker (Sold) 20130729
Made In USA
Klipsch - 'Keepers of the sound'
Klipsch Tangent T-4000 "horn loaded" three-way floor standing loudspeakers. Massive 12" woofer with the legendary Klipsch mid & tweeter horns. Made in Arkanssas USA. These speakers can support very low bass frequency. First-rate for home theatres and audiophile listing enjoyment. Used, but in great condition.
A bit about the company:
Paul Wilbur Klipsch has constantly promoted the use of "proprietary horn-loaded technology" as part of its goal to produce speakers which:
1) Are high in efficiency (sensitivity), 2) are low in distortion
3) have wide dynamic range
4) exhibit controlled directivity (directional radiation pattern) and,
5) have a flat frequency response, (no unnatural emphasis in the bass, mid-range or treble).
These great speakers are no exception.
Specifications:
* Manufacture: Klipsch
* Series: Tangent
* Model: T-4000
* Built in: 1994
* Dimensions: 15.2" x 14.2" x 35.75" tall
* Enclosure: Medium density fiberboard construction
* Enclosure Type: Bass reflex via triple front-mounted ports
* Finnish: Matte-finish Black vinyl
* Frequency Response: 38Hz-20kHz ± 3dB
* High Frequency Horn: 90(o)x40(o) Exponential Horn
* Mid Frequency Horn: 90(o)x40(o) Exponential Horn
* Midrange: K-53-K 1.5" Phenolic diaphragm compression driver
* Normal Impedance: 8 ohms
* Power Handling: 125 watts maximum continuous
* Peak Power Handling: 625 watts
* Sensitivity: 97dB @ 1watt/1meter
* Tweeter: K-76-K 1" Phenolic dome compression driver
* Weight: 60 lbs. (27.2kg)
* Woofer: K-27-K 12" Fibre-composite cone .
Price : RMsold
Last edited by HiFiLab on Thu Oct 31, 2013 3:35 pm; edited 1 time in total (Reason for editing : sold)
HiFiLab
Number of posts : 2967
