Creek 4140 S2 British Stereo Intergrated Amplifier (sold)
2 posters
Selling a British made Creek Integrated Amplifier Model 4140S2 with Phono Input
Good working condition ;
Inputs for Disc. Tuner, CD, Tape (Play & Record),
Stereophile comment in a review comparision "..To be sure, there are several sub-thou British integrateds out there that offer excellent entry-level sound quality.
I love the little $795 Creek 4140S2, for instance—I had one through here a while back and was really impressed by how downright satisfying it sounded, even when surrounded by much more expensive gear.
And the Creek's got a terrific switchable MC/MM phono stage to boot—one that alone is worth the entire price of the 4140S2.."
"The disc circuitry of this design is capable of reproducing the very best from analogue disc, via either moving magnet or moving coil cartridges. this is achieved by separating the circuit into three stages , with low noise transistors and IC's. RIAA equalisation is very accurately achieved with both active and passive circuitry employing only the highest audio quality components .
The IC line stage is capable of amplifying the high quality output from the analogue stage or the demanding signal quality of the latest compact disc players .
The power stage of the 4140 is similar to the 4040, but it is more rugged and sophisticated , it is protected from damage by a circuit , that will automatically disconnect the loudspeskers from the amplifier in the event of a short , or a component failure. This makes it suitable for use with a wide range of loudspeaker loads and different input signals . It is truly an audiophile product of the highest order ."
SPECIFICATIONS .
Power Output : One channel (8 ohms) 30 watts
(4 ohms) 40 watts .
Distortion : THD at rated output (1kHz 8Q) Less than 0.1% .
Noise : Referenced to rated output at 1kHz ( weighted )
(MC)-62dB
(MM)-70dB
Tuner/CD/Tape-85dB
Separation : Disc (MC) 40dB
Disc (MM) 50dB
Tuner/CD/Tape 50dB
Inputs : Disc (MC) Sensitivity 0.1mV , Loading 1Kohms
Size : W 420mm x H 64mm x D 220mm .
Weight 4.5kg .
Price : RMsold
Last edited by HiFiLab on Sat Jan 17, 2015 9:50 pm; edited 2 times in total (Reason for editing : reduce price)
- Number of posts : 2967
BUMP
HiFiLab wrote:
BUMP
BUMP
HiFiLab wrote:
BUMP
BUMP
UP
BUMP
Contact : Simon Ting 013612507
Re: Creek 4140 S2 British Stereo Intergrated Amplifier (sold)
Can trade with Cambridge Audio A5 or nego the price?
Matt Thunderstrike- New Member
Registration date : 2014-12-11
» Creek Integrated Stereo Amplifier 4140
» Creek model 4140 s2 intergrated amp (SOLD)
» Creek Evo British Stereo Integrated Amplifier (sold)
» CreeK CAS4040 S1 British Stereo Integrated Amplifier
» Creek Special Edition Stereo Intergrated Amplifier 5350SE (sold
