A simple computer (non) audiophile setup guide
A simple computer (non) audiophile setup guide Empty A simple computer (non) audiophile setup guide
Post by STC on Mon Jan 20, 2014 10:37 am
Dear all,
Anyone here using Jriver with Mytek? I am interested to know if the internal sync functions in USB2.0 mode for DSD. The various settings are too complicated for my simple mind and would love to hear from the experts here.
Thanks.
STC
STC
Number of posts : 415
Registration date : 2010-08-15
Source(s): Ambiophonics setup.
Speakers: Electrostatics
http://goo.gl/CF1C6B
A simple computer (non) audiophile setup guide Empty Re: A simple computer (non) audiophile setup guide
Post by VS126 on Tue Jan 21, 2014 7:14 pm
Yes, works perfectly with JR19 in USB 2 for native dsd playback.
VS126
VS126
Number of posts : 640
Source(s): MacMini, 16GB RAM, SSD with Clones mPsu / Clones Asher DSD Dac
Amplification: Crayon CFA 1.2, Red Dragon S500, Clones Audio 25PM /AP2
Speakers: Spatial Hologram M3 Turbo S, Spatial Lumina 12Be Statement and soon Spatial X-1 Uniwave with Vinnie Rossi Lio 4 channel Ultracapacitor amp.
Post by STC on Tue Jan 21, 2014 7:59 pm
What's your firmware's version and do you use a PC or Mac? My DAC is still using the old 1.7.1 FW and with 1.33 driver I could play Mytek in native DSD. But there was occasional clicks at stop and play. I didn't pay much attention to DoP then.
Two weeks back I crashed my PC and reinstalled everything but mistaken I installed the latest 1.34 driver. I was stuck playing all my DSD files in DSD in DoP mode but it was such a revelation.
Two days ago, I realized my mistake and tried with the correct version but I still think JRiver with DSD in DoP has the edge over DSD natively in the 1.7.1 plus 1.34 combo over 1.7.1 plus 1.33. Even though I couldn't use the real DSD playback as 2 x 64DSD in DoP and DSD setting with the old FW.
It maybe possible that DSD over DoP to sound better in JRiver as they are the one who developed DoP method or contributed to their development.
I will be getting the firewire adapter and try with the latest FW. If you get a chance try the above combo and I think they are pretty transparent.
STC
STC
Post by STC on Tue Jan 21, 2014 9:09 pm
Sorry. I got carried away and completely forgotten about the main issue. JRiver's recommendation for DSD native playback is benchmark 3000 and above. Mine is around 2480. I5 processor and 4GB RAM.
Any idea what would be the minimum requirement be? And what settings do you use for aiff playback.
Thank you.
STC
STC
Post by STC on Fri Apr 11, 2014 10:23 am
After updating to 1.7.6 FW, I find listening to files sampled at 44.1, 48 or 98kHz tiresome if I let Mytek to use the 2xDSD mode. It shows HDSD for "upsampled" aiff or wav files. The best to my ears are files played natively at their original sampling rate.
Anyone else experienced this?
STC
STC
Post by bal on Fri Apr 11, 2014 12:13 pm
Quick questions... how much is the Mytec, and is there a local distributor?
Many thanks guys
bal
Moderator
Moderator
Number of posts : 1146
Speakers: maggie 1.7
Post by VS126 on Fri Apr 11, 2014 12:22 pm
Go to PCM and choose native.
Do not upsample it.
Always sounds better playing native.
Bal, dealer is in amcrop mall.
I hv a perfect used runin condition unit if you are interested
VS126
VS126
Post by STC on Fri Apr 11, 2014 12:28 pm
Thanks VS126. So it must be true that I am hearing the extraneous noise due to upsampling.
STC
STC
Post by VS126 on Fri Apr 11, 2014 1:36 pm
Cld be, play around it.
It is a good dsd dac.
VS126
VS126
Post by bal on Fri Apr 11, 2014 2:15 pm
VS for some strange reason I seem to have misplaced your handphone no. Could you whatsapp me?
Many thanks. Could be interested in the mytec
bal
Moderator
Moderator
Post by STC on Tue Jan 19, 2016 8:44 pm
A simple computer (non) audiophile setup guide.
I have just replaced my 5 year old laptop with Intel NUC miniPC. It is a simple solution and relatively cheap.
Cost:
1) N5Cpyh = RM600
2) 4GB RAM memory = RM90
3) 120GB SSD = RM223
For display, you can access from your smartphone using Microsoft Remote Desktop app. For OS, I am using Windows10 with JRiver. For most of you, you can save on the OS by using Linux.
As far as the sound is concerned, I do not hear any difference between i5 and Celeron processor. In fact, I have never heard a single break, pop or click with the NUC even though it is not battery operated. Previously, I used to store the DSD files in my laptop and the rest of the files in NAS. Now, all files are in my NAS streamed via WIFI. I do have Cat6 wired connection available but I find WIFI is free of breaks and JRemote control works flawlessly in WIFI mode.
Memory usage is about 55% and CPU too hovers around there. It should be much lower without any DSP or REW room correction engaged.Noise is negligible when the CPU fan is set to quiet mode. The NUC is about 8 feet away and it is in audible to me. I will be further tweaking the system to bring down the CPU usage if necessary. So far no red flags yet.
To ensure the best sound quality always disable internal volume and send the data to DAC ( in my case, MYTEK).
STC
STC
