Polk Audio RTi10 High Output Floorstanding Loudspeaker (Sold)
REAL WOOD, REAL HIGH PERFORMANCE
Why settle for vinyl speakers when you can have the warmth and beauty of real wood at the same price, with speakers from the RTi Series. They are wonders of industrial design: real wood, radiant with metallic highlights and racing car lines. Classic Polk performance in a design that speaks to today's high-end home decor. True performance art. Beware the competition, indeed!
We at Audiotronic are proud to be part of the Polk Audio family and we are going to kick a** with the new RTi Series!"
So said Gary McCrystal of Audiotronic South Africa upon demo-ing his first shipment of RTi Series speakers, which included this RTi10 floorstanding loudspeaker. Audiotronic deals in mid- to high-end audio, and has been a Polk Audio Dealer/Distributor since 1996. Gary likes to call our Export VP, Joe Graham, and go on and on about how impressed he is with the RTi Series.
INNOVATIVE DESIGN"The XXXX people are all upset. Polk value beats them hands down. Together with the brilliant service we've always received from you guys, beware the competition!"
The new standard in all out musical performance, the RTi10 floorstanding loudspeaker is the epitome of "Real Wood, Real High Performance." Its two 7" woofers benefit from having the surface area of a single large woofer with the low-mass and acceleration of small woofers. So RTi10 bass response is tighter, punchier, more accurate; accentuated by the addition of PowerPort Plus Bass Venting Technology.
- Dynamic Balance® polymer composite drivers for smooth wide-range response with low distortion.
- PowerPort® Plus bass venting for superior clean, low distortion bass that you can really feel.
- Acoustic Resonance Control (ARC Port) technology for more natural midrange reproduction.
- Dual, bi-ampable gold-plated 5-way binding post inputs (with wide holes for large-gauge bare wire connections) for the most secure connections and the most versatile wiring applications.
- 1" silk dome tweeter with a neodymium magnets for clear, detailed highs; heat-sinked (shown right) for superior heat dissipation, power handling and reliability.
- Two 7" woofers have the surface area of a single large woofer with the low-mass and acceleration of small woofers, for a high force-to-mass ratio -- bass response is tighter, punchier, more accurate.
- Butyl rubber surrounds for high performance durability
- Acoustically inert stamped driver baskets.
- Floating anti-diffraction grilles minimize grille diffraction for spacious, 3-dimensional imaging.
- Magnetic shielding for safe placement near video sources.
- Mylar bypass capacitors in the crossovers extend high frequency response and improve detail and transparency.
Anti-Resonant Enclosure
Cabinet resonance can ruin the sound of an otherwise well-designed speaker. You don't want to hear your speaker cabinets humming along with the music (they don't even know the words), you want to hear the uncolored sound launched by the drivers and tweeters. We take special pains to make sure that Polk speaker cabinets are resonance-free. All wood cabinet Polk Audio loudspeakers are constructed of costly low-resonance MDF instead of the cheaper and more resonant particle board used by many competitive speaker brands. RTi Series Speakers feature additional anti-resonance strategies, like asymmetric braces.
- All-MDF construction with massive asymmetric cabinet bracing ensures resonance-free enclosures for accurate sound. (Cutaway view of RTi12 shown left, bracing is similar on other RTi models)
- Adjustable leveling feet in an outrigger base to provide stability on any type of flooring.
- Real Wood finishes at vinyl prices.
PowerPort® Plus
For the new RTi10 and RTi12 Floorstanding Loudspeakers, Polk engineers went a step beyond PowerPort Bass Venting with PowerPort® Plus. PowerPort Plus works with two ports (front & rear) and a series of internal "plates" (as opposed to PowerPort's single port) to further reduce air turbulence at the mouth of the bass port, and increase bass efficiency. PPP allows even lower frequency tuning and lower turbulence for less noise and distortion, and more big musical bass, even at lifelike volume levels. This technology delivers performance that vastly exceeds conventionally ported speakers with bass that you truly feel, as well as hear. Learn more about PowerPort Plus.
Features
- Acoustically inert, asymmetrically braced 3/4" MDF cabinets, finished in Real Cherry Wood or Real Black Oak veneers.
- Dynamic Balance polymer composite driver for smooth wide-range response with low distortion.
- 1" silk dome tweeter with a neodymium magnet for clear, detailed highs; heat-sinked for superior heat dissipation, power handling and reliability.
- Two 7" woofers have the surface area of a single large woofer with the low mass and acceleration of small woofers, for a high force-to-mass ratio -- bass response is tighter, punchier, more accurate.
- Butyl rubber surrounds for high performance durability.
- Timbre-matched to fit into any Polk Audio home theater or multi-channel music system for a more realistic, more seamless surround sound environment.
Price : RM Sold
Last edited by HiFiLab on Thu Sep 11, 2014 5:16 pm; edited 3 times in total (Reason for editing : sold)
- Number of posts : 2967
sold
HiFiLab wrote:
BUMP
BUMP
HiFiLab wrote:
BUMP
BUMP
UP
» Polk Audio RTi 12 Floorstanding Speakers (SOLD)
» Polk Audio LS 50 Floorstanding Speakers (Used) SOLD
» Polk Audio TSi400 Floorstanding Speakers (Used) [SOLD]
» Vintage Polk Audio LS50 floorstanding Speakers ( Sold)
» Polk Audio T50 Floorstanding Speaker (Used)
