Marantz CD63KI Repair
Marantz CD63KI Repair Empty Marantz CD63KI Repair
Post by adrian4454 on Wed Jun 25, 2014 11:19 am
Got some rather amateur caps changing stuff I did like to share~
How long can one keeps their old faithful going on and on and on..? Best equipment will also have a life span.. it will eventually fail.
It fails even faster when the circuit has been modified.
Look at those copper rich coating~
Marantz CD63KI Repair Marant10
Well this is for my case of my beloved Marantz CD63KI. Have been a year or so that I did this SPDIF stealing direct from the  SAA7435, I believe that I didnt do it correctly where I shut too much current to ground. Gradually the player starts to skip music more and more often, up to a stage where nice melody started to sound like hip hop.
To my horror, when I open the top casing and found carbon like deposit around most of the noise filtering caps.
Have anyone seen this kind of phenomenon before? Suppose failing caps should have bulging top or side, instead this is leaking carbon from the bottom.
Marantz CD63KI Repair Marant11
Time to search from replacements online. Went on with the best Elna can offer, Silmic II, and was expecting to cost a tons, but it was rather cheap. Certain values are not available with Elna Silmic II were replaced with Nichicon Fine Gold or other range of Elna caps. Generally, the Silmic II is bigger in size compare to Elna from another range, could be due to the silk fibers inside.
Marantz CD63KI Repair Marant12
Marantz CD63KI Repair Marant13
Now that's done, I finally manage to change 70% of the total capacitors in the player, The analogue output stage caps are un-touch because those do not suffer from the weird phenomenon and neither do I use the player as a player, but rather a transport; it isnt the best candidate for a transport, but for being a cheap ass, I havent have got much spare cash to change to a proper one Smile And I am glad when I turn on the power again, everything works and no more hip hop. I can't clearly say there is a sound improvement; as I only use it as transport, but I did have a better peace of mind knowing my baby now has an extended life span.
Thanks for reading; below is the before and after photo.
Marantz CD63KI Repair Marant14
Marantz CD63KI Repair Marant15
adrian4454
Number of posts : 691
Marantz CD63KI Repair Empty Re: Marantz CD63KI Repair
Post by scwong on Fri Jun 27, 2014 2:08 pm
Smile interesting. With steady hands and a soldering iron, life of most electronic equipments can be extended...n great for the environment.
scwong
Number of posts : 211
Source(s): cd format
Amplification: pre/pwr
Speakers: bookshelf
Post by boxer on Fri Jun 27, 2014 10:58 pm
good effort in documenting with shots of the works done. Silmic II & fine gold are indeed excellent caps without breaking the bank. Another is panasonics fc & fm range, got good results with them. Btw, from which site did you get them elnas? might wan to stock up some values myself to recap my aging/antique hifi....
boxer
Number of posts : 564
Post by adrian4454 on Sat Jun 28, 2014 9:47 am
Hi sc, thanks. Steady hand alone won't do it. Need a lot of trial n error. Did quite some soldering before this, learn a lot from mistake, luckily those were of cheap pcbs. Otherwise I don't have the gut to do it.
Hi boxer, I got all those from part connexion. I also got 2 pana FC caps, as I miss out during my 'intense' study of which caps to change.
adrian4454
Post by mike126 on Sun Aug 14, 2016 9:19 am
Hi Adrian, nice work...I have the same CD player, but mine got different problem with it probably I have kept it too long !!! it wont open, play etc..... the gear also worn out so I have decided to send to a friend shop to do it.....hope it can be safe....I will keep it update....cheers
mike126
Number of posts : 2
Registration date : 2016-08-14
