Optoma, Epson, BenQ Projector 3D Glasses, SONY too now! 1 Year 1-1 Exchange
3 posters
Please LIKE US @ facebook.com/Actsessory
Please scroll down for other brands / models:
NOTE:- Get Original Glasses for maximum efficiency, as there are made specifically to pair with their own models for best natural color, contrast, deep black reproduction, maximum brightness.
3rd party glasses have different color tone glass lens, especially DLP glasses, and wont block the white/reddish tint sync flash, not to mention their build quality and different specification as well.
Optoma ZF2100 3D RF Glasses
Model: BG-ZF2100GLS
- Clearer, brighter 3D video/images with higher improved contrast + black level.
- Easy to setup and use - Always in sync with no line-of-sight like DLP required.
- Lightweight, stylish design with interchangeable nose piece for customized comfort
- Fully rechargeable, long life Lithium Polymer battery
- Come with cleaning cloth and soft bag to keep your glasseing looking new always.
Designed for use with Optoma projectors with 3D VESA output synchonization system.
**Works for other brand projectors' certain models too e.g Mitsubishi.
* Stylish, lightweight, foldable design - only 39g
* One size for all - fits over prescription glasses
* HD resolution to both eyes using active 3D technology
Developed in parallel with our “Full 3D” projectors, the ZF2100 system is optimised to provide you with higher contrast & brighter images than ever before, while eliminating tedious issues with emitter placement, limited range and potential interference commonly experienced when using Infra-red.
Problems with typical Infra-Red (IR) Glasses are:-
-Easily lose sync
-Difficult to install as it..
-Interferes with remotes
Fully rechargeable, Optoma ZF2100 glasses give you the peace of mind that comes with knowing both installing and using them will be hassle free.
P/S: Requires 3D-RF Emitter BG-BC100B (Available, sold separately) to function with
Compatible with following products:
DH1011, EH505, HD131X, HD25, HD25-LV, HD300X, HD91, W505, EH300, GT750,
HD131Xe, HD25e, HD30, HD33, W401, X401, EH503, GT750-XL
Package comes with:
- ZF2100 Glasses
- Cleaning Cloth
- Silky Soft Carry Pouch
- USB Charging cable
- 2pcs nose pieces for customized comfort
- User Manual
- Documentation
SPECIFICATION:
Model Name/ Part No : ZF2100 Glasses / BG-ZF2100GLS
Operating Frequencies : 96/100/120/144Hz (44/50/60/72Hz per eye)
Operating Temperature: 0'C - 40'C
Dimensions : 170 x 168 x 40 (mm)
Weight : 39g
Battery Rechargeable Lithium Polymer - Up to 15 Hours use
Range Up to 40m (Dependent on environment)
Storage Conditions ≤90% Humidity
Display Requirements : Projector / Display must have a “3D Sync” connector (VESA DIN3)
It is RM295 /pair, Brand New Sealed.
*1 Year Local Warranty by Actsessory Shoppe.
*1 to 1 Exchange/Replacement policy, on manufacturing defect
_____________________________________________________________________
Optoma RF 3D Emitter
Model: BG-BC100B
- Designed to work with 3D RF Glasses (ZF2100)
- Advanced timing technology to overcome interference
- RF transmission range up to 150 feet
- Three feet VESA cable included for flexible placement options
- Pairing with ZF2100 glasses allows multi-emitter environment
RF 3D Emitter Compatible Models:
HD25, HD25-LV, HD25E, EH300, HD33, HD3300, HT1083-3D, HD83, HD8300, GT750,
TW865-NL, GT750E, X401, W401, 3D-XL, W505, EH505, X605, HD131XE
Package comes with Emitter and cable (3.5mm jack / VESA 3-PIN mini DIN)
Quick Start Guide
It is RM149, Brand New Sealed.
An OPTOMA ZF2100 System Package (Optoma ZF2100 + BG-BC100B)
It is RM385, Brand New Sealed.
Optoma 3D Glasses ZD302 DLP-Link
Model: ZD-302 (Red)
- DLP-Link 3D Glasses, foldable design
- Lighter (Only 32g) and more comfortable than ZD301 (previous model)
- Stylish Outlook Design for DLP-Link 3D ready projector, e.g BenQ Full HD DLP Projector
- Rechargeable battery design
- Excellent definition and no flicker
- Support 144Hz frequency, backward compatible with 96/100/120Hz system.
- Auto shutdown for saving battery life
Red & Black Color
- Distance < 15 m(The distance is from the projector to the screen gain value @1.0)
ZD302 does work well, they are lighter and fit better than ZD301 and they are meant to give a more enhanced and vivid colour picture.
With DLP Link technology, the 3D glasses synchronise with the image on screen.
Comes with 3D Glasses, Soft Carry Pouch, Cleaning Cloth, 2pcs Nose Piece, USB Cable and User Manual.
Compatible with Optoma HD25/HD25e/HD33/HD3300/HD83/HD90, BenQ, Acer.. etc Full HD DLP 3D Projector Brands.
It is RM350, Brand New Sealed.
BenQ New 3D Glasses II D4
Model Code: 5J.J7L25.002 / 5J.J2W25.001
Enjoy the Fantastic New World of 3D!
- D4 is the latest BenQ 3D glasses (4th Gen), more stylish, lighter weight, more comfortable and larger viewable area than previous D3
- Exceptionally designed to provide an immersive 3D viewing experience with BenQ’s DLP Link-enabled projectors (BenQ W1070, W1080st, MH680, W1500, W7000) for best performance.
- Rechargeable Li Battery
- Support 96, 100, 120, and latest 144Hz Active Shutter
- High Sensitivity and Fast Respondence
- Compatible with other DLPLink 3D Technology too.
Comes with BenQ 3D Glasses, Silky Soft Case, Cleaner, User Guide, USB Charging Cable
~BLACK Color.
It is RM250, Brand New Sealed.
EPSON ELPGS03 Full HD 3D RF Glasses
Part Number: V12H548007, V12H548006
~3D Adventures Like Never Before~
- GS03 Active RF (Radio Frequency), these glasses operate without "Line of Sight"!
- Crystal-clear 3D entertainment - enables easy viewing of 3D movies and games
- Sleek, lightweight design for prolonged use
- Easily adjustable - offers the ideal fit for anyone, even those wearing glasses
- Rechargeable, a 3 minute quick-charge feature for up to 3 Hrs of battery life.
- Provides the BEST and brightest and more natural color .image for Epson range projectors
- 1 size fits all, adjustable for customized fit
- Enjoy the immersive, wraparound visuals of 3D movies and games.
* For all Epson RF 3D Projectors.
* LCD TN Lens
* Auto Shutoff
* Supports Frame Packing, SBS, Top and Bottom
* Refresh rate of 240Hz, 480Hz
Including the PowerLite Home Cinemas EH-TW6000W TW6000 TW5900 TW8000 TW9000W, 2000, 2030, 3010, 3010e, 3020, 3020e, 5010, 5010e, 5020UB, 5020UBe, 5030UB, 5030UBe, and 750HD; Pro Cinemas 4030, 6020UB, and 6030UB; and the PowerLite W16 projector.
* User Guide
It is RM380, Brand New Sealed.
3D Active Glasses for EPSON 3LCD Projector
- RF Bluetooth Active Shutter 3D Glasses
- Ergonomic design, exquisite appearance
* Works the same as Epson original glasses above.
Compatible with: 2000 2030 3020 3020E 5020UB 5020UBE 5030UB 6030UB W16. Pro Cinema 6020UB, TW5810, TW6510, TW6515, TW8100, TW8515, TW9100, TW9515
Powerlite 3010, 3010e, 5010, 5010e, 6010EH-TW3600, EH-TW5800C, EH-TW5900, EH-TW6000, EH-TW6500C, TW8500C, EH-TW9000, EH-TW9500C,ELPIE01, ELPGS01
Comes with 3D Glasses, Soft Carry Case, Cleaning cloth, USB Charging Cable, User Manual.
It is RM135, Brand New Sealed.
Contact O1 261169 17
Location at Subang Jaya ss14 / by Postage.
Brought to you by Actsessory Shoppe:
- [You must be registered and logged in to see this link.]
[b][You must be registered and logged in to see this link.]
Please LIKE US @ facebook.com/Actsessory[/b]
Model: BG-ZF2100GLS
-Easily lose sync
Package comes with:
- ZF2100 Glasses
- Cleaning Cloth
- User Manual
- Documentation
SPECIFICATION:
Weight : 39g
Model: BG-BC100B
Quick Start Guide
Model: ZD-302 (Red)
Red & Black Color
~BLACK Color.
* LCD TN Lens
* Auto Shutoff
* User Guide
Re: Optoma, Epson, BenQ Projector 3D Glasses, SONY too now! 1 Year 1-1 Exchange
That's all the moment... anything else?
All below market price, 1 Yr warranty, 1-1 Exchange.
So many items in one post, confusing,but really very good bargain prices.
klimal- Frequent Contributor
- Number of posts : 200
Registration date : 2009-11-11
Source(s): SLAT L75, OPPO 203D, Asus TinkerBoard / Topping D90
Amplification: LL9226 SUT, AHT Non Sig., EAR834 clone, BAT VK-3000SE, BAT VK150se, Emotiva XPA7 Gen3
Speakers: SB Acoustics Rinjani front main, DIY SBA Satori Center, , ELS3 sides Epos KI overheads. , Subwoofers SVS SB16Ultra, PC13Ultra
Thanks for the support klimal , appreciate that.
Ready stock ready deal, other models may require for quotation as well
Pricings are all below market price and 1 year 1-1 exchange warranty.
Genuine Optoma/BenQ/Epson 3D glasses.
There will be plasma TV glasses soon.
LG CINEMA 3D Glasses Polarized Passive, AG-F200 available.. [/size]
Usable on all passive 3D TV (Sony, LG, Samsung, XiaoMi, etc.. even on AOC 3D monitor and more)
2 pairs in a box (Orange and White colors with a microfibre cleaning cloth), every glasses comes with a specific code, guaranteed Original LG product or money back.)
RM55
RM55
NEW ON SHELF - Toshiba 3D Glasses for Panasonic, Sony, Epson, JVC, Sharp, Mitsubishi....models.
Model: FPT-AG02
Dimension: 17.3 x 17.3 x 4.2 cm
Weights at 35g only.
The exact same technology with the Panasonic TY-EW3D3MC 3D glasses
100% compatible with the below models:
- Panasonic Projector AE-7000EH, AE-8000EH, PT-HZ900C
- Panasonic TV TH-P42UT30C, TH-P42ST30C, TH-P42GT20C, TH-P46GT20C, TH-P46UT30C, TH-P46ST32C, TH-P46GT31C, TH-P50VT20C, TH-P50ST30C, TH-P50GT30C, TH-P50UT30C, TH-P55GT32C, TH-P55VT31C, TH-P55ST30C, TH-P65VT20C, TH-P65VT30C, TH-85VX200C, TH-152UX1C, TH-P103VX2--C
- Epson W5800C, TW6000, 6500C, TW8000, 8500C, TW9000, TW9500C, 3010, 3010e, 5010, 5010e, 6010
- SONY VPL-HW30ES, HW50ES, VW90ES, VW95ES
- SHARP XV-Z17000A, XV-Z30000A
- JVC DLA-XC380, XC388W, XC5800, XC7800, XC780, XC980, XC388RB,XC788, XC988
- Mitsubishi HC77-747DW, HC77-70D, HC77-80D, HC77-787, HC7800D, HC7900, HC8000D, HC9000D
- Toshiba 55ZF1C
Rechargeable, comes with the charging cable.
Brand new sealed.
RM139, 1 Year 1-1 Exchange WARRANTY
Model: FPT-AG02
- Toshiba 55ZF1C
Brand new sealed.
**All models listed above in stock.
Save Malaysia from floods...
LIKE for our Facebook - [You must be registered and logged in to see this link.]
All models ready stock ya..
See you there...
Actsessory Shoppe, with Maxx Audio Visual are participating in the coming KL International AV exhibition in J.W.Marriott KL.
We are most flattered to see you there!
* 3rd-5th JULY 2015
* FREE 4th Edition Audiophile Commemorative CD &
RM5 BHPetrol Voucher for Every Ticket Purchase
While Stock Lasts !
* 3rd-5th JULY 2015
While Stock Lasts !
ready stock, especially the BenQ and Optoma glasses for their hot entry level projectors.
There will be Sony glasses soon, for Sony projector
Sony Infra Red Active 3D Glasses for Sony Projectors.
Rechargeable Battery
Comes with charging cable, and a soft pouch.
Original Sony product.
Works for Sony HW30ES, HW40ES, HW50ES, HW55ES, VW1100,
Epson 5800, TW6000, TW6500C, TW8000, TW8500C, TW9000, TW9500C,3010, 3010E, 3010WN, 5010, 5010E, 6010
Mitsubishi HC7900DW, 7800D, 8000D, 9000D
Panasonic AE7000, AE8000, HZ900C
Sharp XV-Z30000, Z17000, Z48000
JVC DLA-XC380, XC780, XC388. XC788. XC988
* Compatible with Sony, Samsung, Panasonic, Mitsubishi, Toshiba, and Sharp Active Shutter 3D ready displays/TVs that use IR emitters.
An essential equipment for your 3D viewing experience, the universal 3D Glasses fully immerse you into the screen. With best-in-class ACTIVE 3D quality and built-in USB rechargeable batteries, the intensity never stops.
- Best-in-class ACTIVE 3D quality delivers full HD playback without the resolution loss of PASSIVE 3D
- Fully immersive vision with the help of the top and side shades universally compatible with ACTIVE 3D TVs
- Lightweight, stylish design with top/side shades that block incoming light rays allows you to focus on the screen with maximum comfort
- Optimized to sync seamlessly
- Exclusively supports SimulView™ technology
RM150, 1 Yr 1-1 Exchange
By chance you have Sony 3D glasses for VPL-HW40ES?
geforce1999- New Member
- Number of posts : 16
Ya, the above SONY glasses is for HW40ES.geforce1999 wrote:By chance you have Sony 3D glasses for VPL-HW40ES?
Ready stock
actsessory wrote:Ya, the above SONY glasses is for HW40ES.geforce1999 wrote:By chance you have Sony 3D glasses for VPL-HW40ES?
Ready stock
It mentioned it is Sony Original product but it is also * Compatible with Sony, Samsung, Panasonic, Mitsubishi, Toshiba, and Sharp Active Shutter 3D ready displays/TVs that use IR emitters. so is it a compatible to Sony product or original Sony product?
Also does it require any emitter for this glasses to watch 3D? Sorry a newbie in 3D
It's original sony glasses.
Sony HW40es has built in IR emitter, so buy and ready use.
Because they share the same transmission technology, thus they are compatible with each other.
There are DLP, IR, Bluetooth, Radio Frequency and so on 3D tech in the current market.
Anyhow, feel free to visit us to take a look if you are nearby.geforce1999 wrote:actsessory wrote:Ya, the above SONY glasses is for HW40ES.geforce1999 wrote:By chance you have Sony 3D glasses for VPL-HW40ES?
Ready stock
I have the same HW40es in the demo room.
There will be more to come
» 3D Glasses: Epson - Rechargeable RF 3D Glasses & Samsung SSG-2100AB Battery 3-D Glasses
» Projector Lamps (Epson, JVC, Hitachi, Mitsubishi, NEC, Panasonic, Sanyo, Sharp, Sony, Toshiba, Yamaha lamp)
» infocus 3D Glasses for projector
» Optoma HD83 Projector 1080P Home Theater Projector (Faulty)
» benq pe8700 projector
