Bill Beard BB100 50 Watt Tube Valve British Audiophile Integrated Amplifiier (Sold)
Made In England
Rare
Up for grabs is my Britsh Built Audiphile Products Bill Beard BB100.
This amp is a 50 Watt push pull design and to my eyes one of the best looking valve amps I've ever seen. It just looks brilliant - especially at nigh with all 18 valves glowing away. ( Like a School of Army )
it will work well with 4 Ohm ESLs that aren't too inefficient, which the manual specifically states. Quads, for instance. It was very good with ProAc 2.5s and should work very well with dynamic speakers that need 50 Watts or less.
Manufacturer's Specification:
Sensitivity (all inputs) variable 0-200mV for 50W
Input overload Unlimited
Power output 50W/channel RMS @ 8 ohms
Bandwidth 20-20kHz
Distortion:
(50W/8 ohms) 20Hz = 1.5% THD
1kHz = 0.4% THD
20kHz = 1.8% THD
(25W/8 ohms) 20Hz = 0.6% THD
1kHz = 0.1% THD
20kHz= 0.8% THD
(5W/8 ohms) 20Hz = 0.2% THD
1kHz = 0.2% THD
20kHz = 0.3% THD
(50W/4 ohms) 20Hz = 0.7% THD
1kHz = 0.6% THD
20kHz = 1.8% THD
(25W/4 ohms) 20Hz = 0.2% THD
1kHz = 0.2% THD
20kHz = 0.8% THD
1kHz = 0.2% THD
20kHz = 0.3% THD
Signal to Noise Ratio better than -85dB at
rated output
Dimensions 460x160x330mm (WHD)
British Built Audiophile Products, 60 Curle Street, Glasgow G14
Professional Review:
The BB100 is a hefty, single-chassis item designed to bring out the hi-fi casualty in all of us. With or without the protective cage in place, the BB100 shouts 'Valves!' because you can see all 18 a'glowing. This conservatively-rated 2x50-watter derives its power from three parallel 'push-pull' pairs EL84s per channel, presenting a very low (2.6k ohm) output impedance to the output transformer for easier driving conditions. The valves are lined up like soldiers behind a complement of four ECC 81s and two ECC82s in the pre-amp section. Each channel in the pre-amp employs one ECC81 in the driver stage, another '81 as a phase splitter and the '82 as a cathode follower. The heaters for every valve in the BB100 are fully DC regulated. To prevent paranoia among those of you who think that valves are a recipe for ensuring your local repairman's fiscal health, the BB100 has been designed to make valve amp ownership a set-and-forget exercise.
For openers, all of the valves are common, inexpensive and durable; just ring PM Components if you don't believe me. Then, to give you a visual confirmation of each valve's well-being, a red LED next to each tube glows when the bottle ages toward senility; this is achieved by measuring the amount of current drawn by each valve. A brightly glowing LED means that you whip out the valve and pop in a fresh one. 'What about biasing?' I hear from those of you with incurable persecution complexes. No sweat: the BB100 operates with a mix of grid and cathode biasing to preclude the need for bias adjustments.
On a personal note, I find all the fear of adjusting bias to be excessive and unnecessary. If I can do it, anyone can. On the other hand, it's been explained to me by more than one manufacturer that no matter how clear the instructions, some brain-dead nebbish is going to set the bias incorrectly and murder an innocent tube. The only reason that I even mention this, since most would willingly trade the inconvenience of manual adjusting for automatic biasing, is the slight trade-off between cathode vs grid bias circuitry. With cathode biasing you get the nice, sweet 'old valve' sound and automatic biasing, whereas grid bias arrangements produce tight, crisp bass more appealing to modern ears while requiring manual adjustment. BBAP has employed a hybrid of the two which works beautifully, so I suppose there's little sonic justification for grid-only biasing.
The BB100 is pretty much dual-mono throughout, with the only shared aspects of the design being the single-piece, double-wound mains transformer and a master gain control (whoopee!). The latter, however, is a double-track knob, so the 'mono-ing' is mechanical rather electronic. With the cage removed and the controls facing you, the back third of the BB100's top surface contains the mains transformer flanked by the separate output transformers. These are wound and constructed to 1% tolerance and are described as a '35% ultra-linear tap design', understressed to require less feedback. The output section also employs 1300uF reservoir capacitors for each channel. The driver stage is a high current design with its own dedicated regulated DC power supply of 4700uF per channel.
The BB100, despite its sensible pricing, is brimming with designer goodies, of which 80% are purpose-made to BBAP specifications. All capacitors are either polypropylene types or low ESR electrolytics, mounted on a double-sided PCB employing 2oz copper tracks. For easier servicing, the main tracks and components are positioned on one side of the board. Internal
wiring consists of computer data transmission cable, a solid core type made from silver-plated copper. The BB100 uses separate star earthing for each channel.
At the back of the amplifier are high-quality gold-plated input sockets for CD, tape in and out, tuner, auxiliary and 'external phono', two fuse holders, the on-off switch and Michell binding
posts which accept just about any connector you'd care to employ short of a DIN speaker plug. Loaded it may be, but the front panel re-affirms the minimalism of this design.
The profusion of knobs indicates dual-mono status rather than a clutch of facilities. At the outer ends of the fascia are the left and right source selectors which possess a nice feel and
positive detents. The centre of the panel contains the master volume control as well as separate left and right gain controls for 'fine-tuning'. Although most users will set these for best overall sound and perform most operations with the master control, users are advised to experiment.
Reminding me of the operation of the Audio Research SP-15, this gain setting flexibility can be used to optimize the sound according to the source. Phono via an external pre-amp, for
example, sounded best with the separate controls at the 12 o'clock position and the master control operation between 10 and 2, while directly injected CD was preferred with the gain
controls at around 9 o'clock. This provided the same arc of operation as with phono and offered the best balance between absolute sound quality and minimum noise -- not that the BB100 suffers from much of the latter.
Used with a variety of sources and the Audio Research SP-14 pre-amp as a phono stage, the BB100 was mated to speakers including the Monitor Audio Studio 10, the Sonus Faber Electa
Amator, the JBL S119 and the Celestion SL700. The first thing I learned is that most sane individuals will have a hard time finding any speakers (of the sort likely to be paired with a #995 integrated amplifier) which this animal can't drive. Indeed, I'm so confident about the BB100's ability to drive all manner of systems that I'm looking forward to the arrival of the Apogee Stage 'budget' model as a potential torture test. If ever there's been a case of a power rating not indicating an amplifier's true prowess, then it's the 50 watts accredited to the BB100.
Even more impressive for many will be its clear, unmuddied, taut lower registers -- probably the best I've heard from any modern valve amplifier at this price point. The extension proved far greater than the capabilities of most of the speakers I employed, hence the need to enlist the JBL S119, a speaker which had only arrived a few days before writing this review. Despite being unfamiliar with this unusual 'omni', I was able to exploit its 8in woofer and meter-high cabinet to find out what the BB100 would do with test tones, synth-generated bass and organ notes. I believe my colleague Pete Clark would call this amp, in modern parlance, a stonker.
All that the BB100 lacks in this area to threaten the big (solid-state or valve) muthas which command far higher prices is the kind of unbridled slam and absolute dynamics which you'd
expect to roll out of a kilo-watt's worth of Krell into something like a Duntech Sovereign. With unnaturally bass-heavy, or more precisely 'bass-dominant' recordings, the BB100 reaches its
limits in style, behaving much like the Wilson WATTs by acting like a filter rather than falling apart. Instead of sounding squashed or compressed, the BB100 simply stops, gracefully and
euphonically. That aside, it's more than enough, in the same way that most cars can break the legal speed limit by at least 15mph.
This behaviour is consistent throughout, and it's especially beneficial when you reach the uppermost frequencies. Amusingly, it's here that the BB100 sounds most like an all-tube design, because the highs positively shimmer. Many modern valve amps seem to be conceived to ape the sound of solid-state electronics, for the simple reason that an entire generation-plus grew up on the latter and would find tube gear 'dull' or 'soft' rather than 'romantic' or 'sweet'. It may just be a matter of rhetoric or conditioning, but it's something which must be addressed, so I can understand the approach. But the BB100 is unashamedly a tube amplifier where it counts, where tube characteristics are strengths rather than weaknesses. And the results, should this amplifier find its way into enough shops, could convert a number of people who think that valves have something to do with plumbing fixtures.
Advertisement
How Beard got 18 off-the-shelf valves to run so quietly I don't know, but the silences are enough to confuse any who believe that all valve amps are noisy. This in itself makes the rite of passage painless for anyone born after 1958, and sales staff will not have to resort to apologies while explaining the pros and cons of valve ownership. Talk about an easy sale: all that the BB100 requires of its owners is an understanding of the need for ventilation, and anyone who's used solid-staters from Krell or Musical Fidelity already knows where not to stack the cassette deck. Which leaves us with the rest of the evidence presented to
one's ears.
The midband of the the BB100 is not a transitional point, a crossover from firm bass to shimmering highs. These characteristics are not as clearly delineated as mere verbal descriptions imply. The midband, which is as precise and clear as is required to produce accurate images, realistic positioning and ambience and smear-free transparency, never approaches a level of hygiene which suggests the clinical or the over-etched. In this respect, it's almost as 'tube-y' as certain classics of yore, but there's no added warmth to upset the overall accuracy. Rather than showing concern for modernists in their initial approaches to valve gear, perhaps I should worry more about traditionalists who dread the thought of valve amps which are indistinguishable from solid-state. They should know, then, that the midband of the BB100 is one of the happiest compromises I've heard, more modern than, say, the Air-Tight, but unlikely to be mistaken for a anything from Salisbury.
Where the BB100 most belies its price and best illustrates its valve heritage is in conveying air and openness. It's a big-sounding amplifier, one which pushes back the walls and pretends that your room can balloon at will. This is one of those all-too-rare products that makes you want to listen more and more, like a novel you just can't stop reading or -- better -- don't want to end. It does this because it's just so convincing in so many ways.
I'm tempted to go mental over this beauty, everything from its performance to its price to the pride of ownership it will confer upon BBAP customers. But I'm also aware that I've yet to try it with what might be natural partners, like the Celestion 3000, the Apogee Stage, the Quad '63, the Martin-Logan Sequel and a number of Maggies, and the company's own outboard phono stage won't be launched until this issue hits the stands.
Could this really be me talking, trying to be cool, calm and collected while witnessing what might be the birth of a milestone in affordable high-end equipment? Exercising caution? Restraint? Naaah... I just don't know how to convert the comic book image of a mind being blown into mere prose.
Note : All 18 pcs tube in Very Healthy Condition
Price : RMsold
Last edited by HiFiLab on Sat Oct 04, 2014 4:57 pm; edited 1 time in total (Reason for editing : sold)
- Number of posts : 2967
» Bill Beard's BB100 Integrated amplifier (Used)SOLD
» Mullard Ecc81 tube British Made 1 pair- sold
» Creek Evo British Stereo Integrated Amplifier (sold)
» Cayin High End Tube/Valve Integrated Amplifier (A-88T) With Upgraded Tubes-Sold
» Audiolab 8000A British Stereo Integrated Amplifier with MM and MC ( Sold))
