Carver sonic holography CM-1090 Stereo Integrated Amplifiers ((Sold)
Description :
The Carver CM-1090 amplifier's sound is very neutral and it's got a wackload of power. Even at low volumes, the CM-1090 excels at being clear and full without loss in detail. There is absolutely no hum or hiss at any volume levels. Designed by Bob Carver, the layout of the various functions and buttons is simple but very adequate. Motorized volume knob and "direct CD" input that bypass the triple tone controls are a couple interesting features. There is also a "B" speaker setting that makes the second pair of speaker act as ambience sound. The circuitry design also consists of Bob Carver's well known "Sonic Hoography" circuit which contributes to its impecable sound without any coloration or distortion. As far as asthetics are concerned, it is very elegant. With it's two analogue "old fashion" power meters combined to an overall modern look, the result is stunning.
Specifications :
Power Amplifier Section
Power Output..................................100 watts RMS per channel @ 8 ohm
.................................150 watts RMS per channel @ 4 ohm
Frequency Response.....................................20Hz to 20kHz (+/- 1dB)
Gain.............................................................29dB
THD.............................................................<0.1% (20Hz -20kHz)
IM Distortion(CCIR or SMPTE).......................<0.5%
Amplifier Input Impedance..............................27 kohm
Pre-Amplifier Section
Maximum Gain at Preamp Out.......................16dB (+/- 2dB)
Maximum Gain at Tape Out............................0dB (+/- 2dB)
Phono Gain at Tape Out.................................34dB (+/- 2dB)
Signal Noise IHF at 150mVRMS Input..............90dB
Phono Signal Noise IHF at 5mVRMS...............78dB
Tone Controls(Treble).....................................+/-7dB (+/-2) at 10kHz
(Midrange)................................+/-6dB (+/-2) at 1 kHz
(Bass)......................................+/-8dB (+/-2) at 100Hz
Input Impedance............................................47 kohm
Preamp Output Impedance.............................470 ohm
Sonic Hologram Generator Image Resolution....5 degree horizontal, 20 degree vertical
Dimensions(w x d x h)....................................48.5 x 39.5 x 13 cm
Weight..........................................................9kg
Miscellaneous :
Remote.........................................................No
Made in.........................................................Japan
Condition.......................................................8/10
Review :
http://www.audioreview.com/cat/amplification/amplifiers/carver-audio/cm-1090/prd_115667_1583crx.aspx
Price : RMsold
Last edited by HiFiLab on Wed Jul 15, 2015 12:04 pm; edited 2 times in total (Reason for editing : sold)
- Number of posts : 2967
BUMP
UP
BUMP
UP
» Used-Carver Pre Amplifier C1 Sonic Holography
» Marantz 1090 Stereo Console Amplifier (SOLD)
» Marantz 1090 Vintage Stereo Intergrated Amplifier ( SOLD )
» Marantz Model 1090 Integrated Amplifier
» Carver CM-1040 Integrated Amp (sold)
