>>>> Emotiva 2x XPA-1 monoblock amps [SOLD]
1 pair of Emotiva powerhouse Reference series XPA-1 in excellent condition. Rated at 500w each into 8 ohms and 1000w into 4 ohms ! These are true dual differential amplifiers, meaning there is complete matching internal circuit tracing and amplification for both positive and negative terminals on each amp! No repairs done. Comes with org double box.
SPECIFICATIONS:
Class: A/B
Channels: 1
Power 8 Ohm All Channels Driven: 500W
Power 4 Ohm All Channels Driven: 1000W
Power Bandwidth: +/-0.05dB
Frequency Response: 5Hz-150kHz(-3dB)
THD: <.007%
SN Ratio 1W: >100dB
SN Ratio Full: >117dB
Damping: NA
Crosstalk: NA
TransformerVA: 1,200
Capacitance: 120,000
Input Sensitivity: 1.8
Input Impedance Unbal/Bal: 20/18
Gain: 32dB
Adjustable Gain: No
Power Requirements: 15A
Connections: XLR/RCA
Trigger: 2-12V/DC
LED Meters: Yes
2 Ohm Capable: NA
Output Devices: 24
Fans: No
Weight: 75.7
Width: 17
Height: 7.75
Depth: 19
Rack Size: 4U
Topology: Fully balanced, fully discrete, quad differential
DESCRIPTION:
You know that sweet spot all amplifiers have? That magical level where things are rich, full, but still open and relaxed?
With the XPA-1, you’ll find that sweet spot at practically every volume level—from the softest pianissimo to the full-throated roar of an orchestral crescendo. And the sound? Big, expansive, powerful, and yet very, very refined, with all the detail you’d expect from a flagship amplifier.
The XPA-1 represents the ultimate expression of our approach to design and construction in our X Series power amplifiers.
FEATURES:
SPECIFICATIONS:
Class: A/B
Channels: 1
THD: <.007%
SN Ratio 1W: >100dB
Damping: NA
Crosstalk: NA
Gain: 32dB
Adjustable Gain: No
Trigger: 2-12V/DC
LED Meters: Yes
2 Ohm Capable: NA
Output Devices: 24
Fans: No
Weight: 75.7
Width: 17
Height: 7.75
Depth: 19
Rack Size: 4U
DESCRIPTION:
FEATURES:
- Fully balanced, Differential Reference design.
- Automatic 120/230 AC voltage detection and switching.
- Multi segment bar graph output level meters with clip detect.
- High resolution, multi segment output level metering with clip detect.
- Advanced microprocessor operating system.
- Discrete front end, no integrated circuits.
- Fully balanced, quad differential input stage, with cross coupled active current sources.
- Darlington VAS stage with optimized C dominant pole.
- External trigger turn on.
- Fully protected from all fault conditions.
- External trigger input/output (3-12 Volts DC - tip positive).
- Soft touch power switch.
- 4RU chassis w/ 15mm solid milled aluminum faceplate.
- IEC power inlet.
- Laser etched serial number badge on the front plate
TheMachinist- Frequent Contributor
- Number of posts : 147
Registration date : 2014-11-08
Re: >>>> Emotiva 2x XPA-1 monoblock amps [SOLD]
Up. Price negotiable. May be able to ship as I have the original boxes.
Price revised. No COD. I can refer you to a reliable shipper who charges $5/kg include custom fees.
» Emotiva XPA-100 Monoblock - sold
» Marantz MA-500 monoblock amps (sold)
» Emotiva XPA-100 Monoblock Power Amplifier [SOLD]
» Stax DA-80M monoblock power amps (Used)SOLD
