Weltronics AMC DAC 8 Digital Analog Converter (Sold
AMC DAC8 - 4 Digital Inputs -- 1 Optical + 3 Coaxial, 2 Outputs -- 1 Digital (BNC) + 1 Analog
APPLICATIONS AND FEATURES
•The AMC model DAC8 was designed to meet professional quality standards for Digital to Analog signal conversion.
•The highest grade of components are used throughout with critical components selected for the sonic performance.
•Double sided, through hole plated, Printed Circuit Board.
•The AMC model DAC8 provides 4 selectable S/PDIF inputs, 3 coaxial and one fiber optic.
•The DAC8 can automatically lock to either 32 KHz, 44.1 KHz or 48 KHz digital sampling rates for use with laser disc players, CD÷Õ or DAT machines.
•The AMC model DAC8 uses the latest generation of bit stream continuous calibration ultra-linear Digital to Analog Converter, with inherently low jitters.
•For those users with digital recording capabilities, the DAC8 has a digital output for connection to DAT, MD or DCC type machines, thus maintaining the ultimate in recording quality
•The AMC DAC8 provided an accurately calibrated output level in accordance with the EIA (Electronic Industries Association) recommended standard of 2 volts. This output level provides the best possible performance particularly for home theater users.
•The fiber optic input provides electrical isolation from Laser Disc players, thereby avoiding conducted interference from Video sources into the Audio chain.
•The superior performance of the DAC8 will provide not only improved technical specifications to your system, it will also significantly upgrade its sonic qualities.
SPECIFICATIONS
•THD 20 Hz - 20KHz and SMPTE IMD: 0.005% A-WTD at 2Vrms
•Signal to Noise Ratio: 104dB "A" wtd
•Output Level: 2V rms
•Frequency Response: 20 - 20 KHz, + -0.3dB
•Channel Separation: 90 dB
•Resolution: 18 bits
•Linearity up to -90 dB: +/-0.5dB
•Input automatically locked to 32K, 44.1K and 48KHz SPDIF digital signals.
•Dimensions (W x H x D): 430 x 82 x 300 mm
•Net Weight: 4.2 Kgs
Price : RM Sold
Last edited by HiFiLab on Wed Feb 25, 2015 7:17 pm; edited 2 times in total (Reason for editing : sold)
- Number of posts : 2967
BUMP
UP
» DPA Little Bit Three Digital Analog Converter DAC (sold)
» NAD M51 Digital Analog Converter /Pre (SOLD)
» SMSL SU-8 V2 Digital Analog Converter (DAC) (Sold)
» AMC DAC8 digital analog converter (Used)sold
» SOLD BRYSTON BDA-3 Digital to Analog Converter (Used)
