QED Qunex Signature 75 Digital Coaxial Cable - 1m
QED Qunex Signature 75 Digital Coaxial Cable - 1m  Empty QED Qunex Signature 75 Digital Coaxial Cable - 1m
Post by raymond88 Thu May 14, 2015 11:49 pm
Item: QED Qunex Signature 75 Digital Coaxial Cable - 1m
Condition: 8.5/10. In original packaging. Used for a while before upgrading.
Price: RM280
Contact: Raymond 012-3816611
QED Qunex Signature 75 Digital Coaxial Cable - 1m  Img_2014
QED Qunex Signature 75 Digital Coaxial Cable - 1m  Img_2015
More info:
http://www.amazon.co.uk/SIGNATURE-SERIES-DIGITAL-INTERCONNECT-METRE/dp/B00138FDXC/ref=cm_cr_pr_product_top
QED Qunex Signature 75 Coaxial Digital Cable 1.0m
Coaxial cables work as transmission lines, therefore, adherence to the 75-ohm standard is paramount for correct digital signal transfer. Qunex Signature 75 interconnect does just that, through the use of excellent materials and optimum cable geometry.
This new cable has been specially designed to offer extraordinary levels of screening, compared to normal digital interconnect cables. The outer conductor wrap and twin Silver-plated braids give excellent noise immunity across a wide frequency range. This, along with the use of Silver-plated OFC conductors, ensures that transmission quality is maintained under the most demanding conditions. The foamed PE dielectric makes the cable flexible and easy to use, when compared to solid dielectric equivalents. QUNEX SR75 is a high precision, high value co-axial cable that will extract optimum performance from the latest generation of digital & video sources for the minimum outlay.
Signature 75 is fitted with special Rhodium-plated versions of the famous Qunex Reference locking phono plugs. Rhodium has low (and stable) contact resistance and is highly corrosion resistant, making it the perfect choice for high quality audio connectors
Digital audio cable, strict adherence to the 75ohm standard means correct digital signal transfer, silver plated braids give excellent noise immunity across a wide frequency range, silver plated OFC conductors, foamed PE dialectric, fitted with Rhodium-plated Qunex® reference locking phono plugs
Features
- True 75 ohm co-axial construction
- Silver Plated 99.999% Oxygen Free Copper conductors
- Strict adherence to the 75 standard means correct digital signal transfer
- Extraordinary levels of screening
- Silver-plated braids give excellent noise immunity across a wide frequency range
- Foamed PE dialectric
- Fitted with Rhodium-plated QUNEX Reference locking phono plugs
Thank you.
Number of posts : 9985
QED Qunex Signature 75 Digital Coaxial Cable - 1m  Empty Re: QED Qunex Signature 75 Digital Coaxial Cable - 1m
Post by raymond88 Fri May 22, 2015 11:21 am
Post by raymond88 Fri May 29, 2015 11:23 am
Post by raymond88 Fri Jun 05, 2015 8:47 pm
Post by raymond88 Tue Jul 14, 2015 2:54 pm
