Mordaunt Short Carnival 6 & Carnival 5 (SOLD)
Selling my entire installation setup due to upgrade.
High performance, cost effective stereo & home theater speaker solution. You will loves Mordaunt Short speaker once you hear it.
and you won't regret buying it.
1) Mordaunt Short Carnival 6 Floorstander Speaker + Carnival 5 (Centre Speaker) : SOLD to a nice gentlemen
It comes with original box (except no polystyrene block) and full manual and accessories. Mint condition, well kept and maintain
Colour : Black
Condition : 8.5/10
Contact : (Whatsapp or SMS) 012-2163733
Serious buyer only.
Kindly make appointment with me if interested.
Item Location : Subang Shah Alam
"Simplicity is the Ultimate Sophistication" – Leonardo da Vinci
Carnival is Mordaunt-Short's entry-level loudspeaker series offering excellent performance across the frequency range. Carnival models manage bass with aplomb, yet convey the finest detail to the listener.
Like all Mordaunt-Short products, Carnival is developed in the UK by a dedicated research and development team and benefits from the company's trademark engineering excellence. Carnival models are ideal for stereo or home-theatre set-ups and have been developed as a complete range making them easy to mix and match.
The sleek cabinets house high performance drive units including an elegant elliptical tweeter design.
Polypropylene capacitors give a clearer signal and improved resolution while low saturation inductors mean reduced distortion and better dynamics.
They also take in bespoke Mordaunt-Short wiring and as with any product from this stable are structurally well braced. The entire range is available in an elegant black finish
Carnival 6 floorstanding loudspeaker
The Carnival 6 is an elegant floorstander which is far more potent than its compact appearance might suggest. It handles 120 watts and offers impressive bass management whilst also being responsive and producing a refined and detailed sound. The ballast/sand enclosure is user-accessible and can be filled with ballast/sand for a faster and tighter bass.
Carnival 5 centre loudspeaker
Developed as a dedicated centre speaker, the Carnival 5 is designed in a woofer-tweeter-woofer configuration for best dispersion and is equally comfortable with dialogue as it is with music. It is ideal for entry-level 5.1 or 6.1 home-cinema set-ups.
Two high performance 3.5 inch woven composite drive units maximize rigidity and reduce distortion. The Carnival 5 is magnetically shielded and supplied with rubber dome feet so that it sits neatly on top of most TVs without causing damage and does not interfere with the picture.
For full details of specification you can also check below
http://www.wokeehong.com.sg/pdf-download/ms-carnival.pdf
Colour : Black
Condition : 8.5/10
Serious buyer only.
- Sensitivity 90dB
- Frequency response 39Hz - 20kHz
- Impedance (nominal) 4 - 8 Ohms
- Drive units 2 x 5.5" Woven Composite Cone - with shielded motor assembly, 25mm Soft Dome
- Crossover 3-Way 1st Order
- Recommended maximum amplifier power 120 watts
- Magnetic shielding Yes
- Speaker dimensions (H x W x D) 910 x 177 x 240mm (35.8 x 7.1 x 9.6")
- Weight 7.5kg (16.5lbs)
- Finish Black
- Grille / Feet / Spikes Yes / Yes / Yes
- Sensitivity 87dB
- Frequency response 80Hz - 20kHz
- Drive units 2 x 3.5" Woven Composite Cone / 25mm Soft Dome
- Crossover 2-Way 1st Order
- Recommended maximum amplifier power 80 watts
- Speaker dimensions (H x W x D) 118 x 430 x 180mm (4.6 x 16.9 x 7.1")
- Weight 4.5kg (9.9lbs)
- Finish Black
- Grille / Feet Yes / Adhesive rubber pads
Last edited by cssam5229 on Wed Sep 14, 2016 5:57 am; edited 9 times in total (Reason for editing : sold)
cssam5229- Frequent Contributor
- Number of posts : 1752
Registration date : 2015-05-06
BUMP
UP
BUMP
Refresh
BUMP
Refresh
BUMP
Refresh
BUMP
Price reduced
BUMP
Refresh
» Mordaunt Short carnival 1 (used) sold
» Mordaunt Short Carnival 8 (Sold)
» Mordaunt Short carnival 1 sold
» Mordaunt Short Carnival Speakers (Used) - SOLD
» Mordaunt-Short Carnival One Speaker (Used) SOLD
