Fururech Daytona 303- new
Friends, it's the little touches like this that set Furutech apart. Engineering plus brains… a goodly combination!......positive feedback online
The very handsome front panel of the 303 provides a constantly updated and highly visible readout of current voltage…which is common enough… but it also gives you the current amperage of system draw, which is very uncommon on devices like these. The 303 is rated for 120 Volts/15 Amps (there is a 230 Volt model available), and with ten outlets it's good to know how close your system is skating to the maximum. (You can even see the amperage fluctuate as the scenes change during a Blu Ray; it's quite an education in power use.)
Once the Furutech Daytona 303 and the Alpha Piezo Powerflux power cables were installed, the results were immediately apparent: improved definition and detail on Blu Ray reproduction was quite evident. Color rendition was better; black and white on Blu Ray seemed to have better gradation and a smoother gray scale. The sound on the Kisto processing showed a lower noise floor, a certain edge and grain to the sound dropped away, and the dynamics of sound swing for SACD in surround mode was improved. The protection circuitry of the 303 didn't darken, congest or restrict the sound performance of our home theater system; rather, it provided greater transparency and an improved sense of musical warmth and richness.
Read more details at:[You must be registered and logged in to see this link.]
- Price at RM12500
-Call Mike @ 0188606677 . product and costing discussion welcome!
Last edited by mike67 on Fri Feb 19, 2016 12:11 am; edited 4 times in total (Reason for editing : update)
» Daytona IC 12 feet (used)
» Furutech Daytona 303 (NEW)
» Furutech Daytona 303 multimode filter (used)
» Furutech Daytona 303 Power Conditioner
» Furuterch Daytona 303 Power. conditioner
