Vintage Bogen MO-200A Stereo 100 Watts Vacuum Tube Power Amplifier ( Used)
3 posters
Made In USA
Great sound. Clean and clear from deep bass up to extreme treble
Bogen MO-200A Tube Amplifier, 200WPC Mono
100WPC Stereo.
Bogen built some of the most innovative tube amplifiers during the golden era of tube amplifiers during the 1950's and 1960's.
Bogen always had transformers that far exceeded the normal specifications for amplifiers sold through commercial channels.
This design consists of two almost separate amplifiers (common power transformer) each with it's own output transformer and push-pull-parallel set of 8417 tubes with 7247 drivers.
The inputs to the 7247 grids and output transformer secondaries are connected in parallel for 200 Watts per channel.
The amplifier can be rewired as a stereo amplifier, each channel with it's own output transformer and quartet of 8417 for 100 Watts per channel.
Chassis is very clean with only slight wear - an occasional scratch, no dents, no rust. There are a couple of very small paper labels still on the chassis.
Amplifier is sold in working condition and sounds very strong. You will be amazed how good this amp sounds.
Bogen MO-200A Audio Power Amplifier Specifications
Model | MO-200 / MO-200A |
Tubes, Output | Eight 8417 beam power tubes |
Tubes, Driver | Two 7247 dissimilar dual triodes ( Upgraded to 12AX7) |
Frequency Response | +/- 1 db, 8-50,000 Hz @ 1 watt |
Power Output | 100 watts, +/- 1 db, 21-50,000 Hz @5% or less THD Per Channel |
Input Terminations | RCA style input connection; Approx. 1 volt RMS input for full output. |
Output Terminations | Screw Terminal Strip, Phenolic. 8 ohms 25VCT (3.125 ohms CT/0.78 ohm) use 4 ohm load 70VCT (24.5 ohms CT/6.125 ohms) |
Comment:
The amplifier consists of two almost separate amplifiers, each with its own output transformer and push-pull-parallel set of 8417 tubes, and a 7247 driver. The inputs to the 7247 grids and the secondaries of the output transfomers are connected in parallel. Needless to say, an octet of matched 8417's, and a pair of matched 7247's would be essential for maximum performance.
If the input sections and output wiring are separated, the unit can be modified to be used as a dual channel power amplifier. Each channel of course has its own output transformer and push-pull-parallel set of 8417 tubes, and a 7247 driver. In such a case, each channel will have about 100 watts output. Both share the power supply.
Note :This amplifier is currently expertly wired for 100 WPC.Stereo and ( Upgraded 7247 tube to 12AX7)
Price : RM 3850
Last edited by HiFiLab on Fri Aug 07, 2015 5:16 am; edited 1 time in total (Reason for editing : coreection)
- Number of posts : 2967
BUMP
UP
BUMP
UP
Re: Vintage Bogen MO-200A Stereo 100 Watts Vacuum Tube Power Amplifier ( Used)
this one 110v or 240v ?
alchemis- Regular
- Number of posts : 78
Registration date : 2011-02-22
240 V, Malaysia voltage
BUMP
UP
BUMP
UP
Hi! Sir, may I know what is the best prices? Thanks!
ikokliang- New Member
- Number of posts : 3
Registration date : 2011-06-27
» Bogen MO 200A power amplifier (Used)SOLD
» Audiovega-V22-A-Vacuum Tube Stereo Integrated Power Amplifier-(SOLD)
» Vintage Audio Research D76 tube stereo power amplifier
» Vintage Silver Pioneer C-73 Pre-Amplifier and SPEC2 250 Watts Power Amplifier ( Used)
» VAL 300BD Vacuum Tube Stereo Amplifier
