Exogal Comet DAC
Exogal Comet DAC
A different energy to propagate out of this galaxy
Representing the award winning Digital Analog Convertor
Assembled & Made in USA
Comet Digital to Analog Converter
The Exogal Comet is a high performance digital to analog audio converter (DAC) playing up to 32/384k and DSD. Just connect your computer, or other digital/analog source, and experience exceptional audiophile quality sound. The Comet DAC does everything you would expect a high-end DAC to do, including balanced and unbalanced analog outputs, digital volume control and asynchronous USB input - all at a sensible price.Benefits:
- Designed for real-life listening with sound that’s amazing, whatever the setting
- Easy digital upgrades for hardware and software
- Controlled by the Exogal Remote App for Android or Apple iOS
Features
- Asynchronous USB, AES/EBU, SPDIF, Toslink, and line level Analog input
- Direct connection analog outputs with 32-bit Digital Volume Control
- Analog Outputs: one pair balanced (XLR), one pair unbalanced (RCA), one stereo Headphone
- Single ended and balanced analog outputs can be used simultaneously. Single ended outputs can be programmed as stereo, or center/subwoofer operation. Single ended outputs have a programmable offset level from balanced outputs
- Controlled by the Exogal Remote App for Android phone or tablet (running 4.3 or higher with BLE support) or an iPad, iPhone 4s or newer, or iPod Touch.
Reviews:
Comet Power Supply Upgrade (OPTIONAL)
DetailsThe EXOGAL Comet Power Supply Upgrade gives you the power to squeeze out that last drop of performance from your Comet DAC! It provides plenty of power to stretch out and render the highest highs, drive the deepest bass, and lets the Comet provide the richest, most authentic sound stage of any DAC on the market.
o
Specifications For Upgraded Power SupplyInput Voltage: 85 VAC to 264 VAC
AC Inlet: IEC320-C14
Output Power Rating: 25W
Output Voltage: 15 VDC
Output Current: 1.7A
Internal Capacitance: 85,000uF
Typical Output Noise: <400 uVpp
DC Cord Length: 5 ft (1.5m)
Dimensions (HWD): 6" x 6.5" x 2.25" (15.24cm x 16.5cm x 5.72cm)
Weight: 2 lbs (.91 kg)
Finish: Black
Includes Auxiliary DC Power Jack
Product pricing: RM10350 with standard power supply. Optional upgraded power supply available with extra cost.
For inquiry, kindly contact 0168606677 Mike( authorized dealer )for product demo and pricing.
Last edited by mike67 on Sat Mar 05, 2016 1:40 am; edited 3 times in total (Reason for editing : update)
» Audioquest Comet speaker cables (New)
» Audioquest Comet speaker cable with 72V DBS -2.5m
» Audioquest Comet bi-wire links (sold)
