Tannoy HTS 200 Home Theater Speaker System
Selling for my customer the following:
Item: Tannoy HTS 200 Home Theater Speaker System
Condition: 8.5/10. Item is in excellent condition, used for few months only before sending to store.
Price: sold
Tannoy HTS 200 speaker system – big, clear sound for big rooms
By Staff writers | 3:35 pm 14/11/2008
If both movies and music is your passion you really should consider the HTS 200. This package would definitely be the natural choice for larger rooms, where the fuller acoustic benefits of the floor standing tower speakers across the front soundstage will be fully appreciated. Their twin 75m (3″) mid bass and 19mm wide bandwidth high frequency driver array certainly packs an extra punch.
Partnered with the centre channel and active subwoofer the complete system delivers accurate and dynamic mid and high frequency combined with rich and powerful bass. This clean and natural acoustic balance ensures that movie soundtracks are delivered with scale and impact while the musical agility, subtlety and detail accuracy essential for the accurate reproduction of audio recordings are satisfyingly presented.
Centre speaker
Tower speaker
Source: Syntec International
Details:
http://media.datatail.com/docs/specs/65352_en.pdf
http://www.soundandvision.com/content/tannoy-hts-200-home-theater-speaker-system#ChoiIi7iw36TSjb2.97
http://www.gadgetguy.com.au/tannoy-hts-200-speaker-system-big-clear-sound-for-big-rooms/
Thank you.
Price: sold
Satellite speaker- Recommended amplifier power: 25 – 100 Watts
- Maximum sensitivity: (2.83Volts @ 1m) 87dB
- Nominal impedance: 6 Ohms
- Frequency response (-6dB): 100Hz to 40kHz
- Drivers: HF: 19mm (0.75″) titanium WideBand dome, with neodymium magnet system LF: 75mm (3.00″) paper cone
- Crossover frequency: 3kHz (LF to HF)
- Weight: 1.3 kg
- Dimensions: 162 x 120 x 170 mm (H x W x D)
Centre speaker
- Recommended amplifier power 25 – 100 Watts
- Nominal impedance: 8 Ohms
- Frequency response: (-6dB) 100Hz to 40kHz
- Drivers HF: 19mm (0.75″) titanium WideBandâ„¢ dome, with neodymium magnet system 2 x LF: 75mm (3/00″) paper cone
- Weight: 2.7 kg
- Dimensions: 120 x 355 x 170mm (H x W x D)
- Supplied accessories: Centre support platform / 20metres (65 ft) speaker cable
Tower speaker
- Maximum sensitivity: (2.83Volts @ 1m) 88dB
- Frequency response (-6dB) 80Hz to 40kHz
- Drivers HF: 19mm (0.75″) titanium WideBand dome, with neodymium magnet system 2 x LF: 75mm (3.00″) paper cone
- Weight: 5.8 kg
- Dimensions: 940 x 120 x 170 mm (H x W x D)
- Supplied accessories: Adjustable coupling spikes and wood floor protectors
- Power output: 100 Watts
- Frequency response (-6dB) 29Hz – 200Hz
- Crossover frequency: 50Hz to 200Hz variable control
- Driver: 200mm (8.00″) long throw paper cone
- Inputs: Line Input (LFE RCA/Phono) or Left & Right speaker level input.
- Power requirements: 115 or 230V AC / 50 – 60 Hz, switching facility on amplifier panel, 60VA
- Fuse ratings: AC 100-120V/60Hz – Fuse: T1.6A L /125V / AC 220-240V/50Hz – Fuse: T800mA L /250V
- Additional features: Energy saving AUTO power function, switchable phase 0 or 180 degrees, crossover and volume control
- Weight 10.2 kg
- Dimensions (H x W x D): 420 x 275 x 405mm (16.50 x 10.80 x 16.00″)
- Supplied accessories:Port tube air flow modifier / country specific mains cable (cord)
Details:
Thank you.
» Psb Imsge series home theater speaker system (Used)SOLD
» JBL 5-Channel Home Theater speaker System (Used) SOLD
» Jamo Home Theater 5.1 Speaker System +free Denon AVR
» Used Jamo S 606 HCS 3 Home Theater System + 2 Surround = 7 Speaker
» Bose CineMate GS II Digital Home Theater Speaker System (SOLD)
