Audio Research SP17 Preamp
Post by vintageguys on Tue Sep 29, 2015 3:03 pm
Selling Tube stereo preamplifier AUDIO RESEARCH SP17 IN GOOD CONDITION
Frequency response Line: +0-1dB, 0.6Hz to 80kHz at rated output. -3dB points below 0.3Hz and above 120KHz.
Distortion (THD) Less than .005% at 2V RMS output.
Noise & hum Line: 12µV RMS IHF weighted at main output with volume low (104dB below 2V RMS output).
Phono: 0.3µV RMS IHF weighted equivalent input noise, shorted input (76dB below 2mVRMS 1KHz input).
Gain Main output line: 11.1dB Processor: 0dB.
Phono: 58dB at 1 KHz.
Record output, line: 0dB. Phono: 47dB.
Input impedance 60K ohms line, 47K ohms Phono, (0.7 to 7mV High output cartridge recommended).
Output impedance 210 ohms Single Ended main; 20K ohms minimum load and 1000 pF maximum capacitance. Record output 60K ohms minimum load and 100pf maximum capacitance.
Output polarity Non inverting
Maximum inputs Line: 9V RMS.
Power supplies Electronically regulated low and high voltage supplies. Automatic 25 sec. warm-up/brown-out mute. Line regulation better than .01%.
Tube complement (2) 6H30 dual triodes
Power requirements 100-135VAC 60Hz (200-270VAC 50/60Hz) 39 watts.
Other Inputs (6): phono, CD, tuner, video, aux, processor. Model SP17L has no phono input.
Outputs (3): 2 main, 1 record (Single Ended RCA connectors).
Push buttons: Volume up, volume down (102 steps, 20 LED indicators), Input, Processor, Mute, Power. All functions on IR remote control.
Dimensions 19.0" (48 cm) W x 5.2" (13.2 cm) H x 10.0"(25.4 cm) D. Rear connectors extend 0.6" (1.5 cm). Front handles are optional.
Weight 12.6 lbs. (5.7 kg) Net; 20 lbs. (9.1 kg) Shipping.
Asking : RM8900.00
Please call / whatsapp 0168008896 Mr Tan for more info.
GOOD LUCK!
http://1.bp.blogspot.com/-s5GFxFVi1ww/Vgo2rcdyvdI/AAAAAAAABbU/9c8d0OM3Fh8/s400/IMG_8350.JPG
avatar
vintageguys
Number of posts : 406
Amplification: WESTERN ELECTRIC 91B MONO POWER AMP
Speakers: WESTERN ELECTRIC 753C / Altec 612A+602A
http://myvintage-world.blogspot.com
Re: Audio Research SP17 Preamp
Post by vintageguys on Wed Nov 08, 2017 10:28 am
avatar
vintageguys
