How much RM$ needed to get a "High" quality stereo system?
Page 3 of 3 • Share •
Page 3 of 3 •
1, 2, 3
Re: How much RM$ needed to get a "High" quality stereo system?
azri wrote:mugen whats your size of te37, is it fifteen inch? do you have to use center cone for vr & vr nuts are consider a must? 2saw, how much for those gramlights? rm3k? theres one set here in aussie its about rm3.6k after currency conversion.
ok back to hifi discussion
The Gram Lights cost me ~4.5K for 16X7"
llsaw- Frequent Contributor
Number of posts: 421
Registration date: 2009-01-20
Source(s): Ayon Audio CD-1S
Amplification: Primare I30
is this some new hifi lingo ?
Number of posts: 2667
Registration date: 2009-04-04
gang-bang at its best
azri- Frequent Contributor
Number of posts: 1028
Registration date: 2009-01-21
Actually it's going to cost one hell of alot of $$$$$$, to get it to sing properly to tune of what most hifi gurus will consider 'good sounding'!!!
Generally speaking at least.
Skimp on any area and the sound suffers!
I think about RM100k to spend on the setup will probably make me very happy!
But don't look at me, I have very diffierent taste la.
Number of posts: 368
Registration date: 2009-09-07
uncle_vic wrote: I think about RM100k to spend on the setup will probably make me very happy!
Probably that amount spent on a setup would make most of us here happy too.
tycham- Frequent Contributor
Number of posts: 714
Registration date: 2009-02-26
Source(s): Digital
Amplification: Solid State
Speakers: Bookshelf
tycham wrote:uncle_vic wrote: I think about RM100k to spend on the setup will probably make me very happy!
But your wife might not be very happy with u.....
Haha.....
I have no problem with this....
Number of posts: 309
Registration date: 2009-03-13
Haha.....
Congratulation to you since both you and your spouse can sing and dance together to the tune of the Thénardier Waltz!
Source(s): Digital
Speakers: Bookshelf
happet,
high quality sound definition is different from one person to another. But in general, the more RM you spend, the better the sound is. However, you can hear a big different comparing an RM5000 set up with an RM15000 set up. But as you go higher up the scale, it starts to be difficult to hear the difference between an RM50,000 set up and RM75,000 set up.
My advice, wait for the KLIAV show this year where you can demo various systems all in one day
elhefe- Frequent Contributor
Number of posts: 638
Registration date: 2010-02-13
Source(s): ClearAudio TT, MF M1 (CDT, DAC, CLiC), SONY MD, ONKYO tape deck, Wadia 170i
Amplification: MF M6i
Speakers: ProAc Response D18
If u r into diy Hifi , u may find a RM 1 upgrade in your system may make big big different. As u go higher end, the more sensitive your system will be. It would have a bigger jump when u have a rm75000 system compare to rm50k system. Everything will make big different.
elhefe wrote:happet,
Wa, very difficult to wait for so long more after hearing multiple auditions at the local hifi shops ... now bekside very itchy di...
So far I think the systems that I audition are varying very much in terms of prices. But the sound quality also varies.
The one I like the most (but definitely can't afford) is the Magico spks with Soulution amp (supreme sound at Audio Image but > RM 80K?? did not dare to ask, just listen only) Did audition the Audio Physic with Exposure Amp and CDP, great sounds too.
My next preference is ATC SCM 19 spks with Krell S 300i and Marantz SA 7003 but cost is roughly RM19K - still above my budget. Krell amp can easily drive the ATC's which are good in mid range, bass is also adequate. If want keep to within my budget then it will have to be the Krell + the Marantz + B&W 685 spks (all from Hiway Laser) plus cables - which comes to about RM14K. But the Krell sounds a bit on the bright side, oozing power ... (I am just about thinking I might get a tube amp to get the warm sounds...
Others that I like is Audio Synthesis' (in Amcorp Mall) BE ONE 3011 CDPlayer and BE One 8011 Amp. Good sounds and when matched with good speakers, perhaps a Harbeth C7 or even B&W should be great. The BE ONE CDP and Amp alone will cost me about RM6K to RM7K, so plus a Harbeth C7 at RM8K, plus some Van den Hul cables will be about RM15K, just about right.
Also went to audition Synthesis Hybrid Tubes + Solid states CDP and Amp at Desa Home Theatre. Quite good with the proper cables - Audioquest G Snakes and Supra Rondo 4 x 2.5. Cost is about RM15K with ATC SCM 11 spks, or about RM19K with ATC SCM 19.
Next up, I went to audition Harbeth SHL5 and Compact 7ES with Quad amp and CDP at Tropical Audio.
I did not like it as much as I thought I would after reading the many good reviews. Cost would be about RM20K if matched with a Rega Elicit amp and Rega Apollo CDP.
And now recently after reading about the bass boom, which I did not experience at Tropical Audio, I went to Rock Corner at Subang Parade, which has the older Harbeths HL5, same as what Tropical Audio demo their Harbeths, I did get to hear the bass booming while they were playing the Wonder Girls Taiwan Special Edition, songs => Nobody, So Hot. (the tunes very catchy and found my bum and shoulders moving from side to side... strange how young girls' voices can affect older men...) But at another time, they played Sade and the Harbeth's bass was very tight and solid. So I think it depends on certain CDs which may generate the low frequencies that cause this.
So now have to decide soon.... sleepless nights await me, sweaty palms, perspiration and mood swings are now almost norm. Why is the hifi fever so severe????
Last edited by happett on Thu Apr 01, 2010 11:53 pm; edited 2 times in total (Reason for editing : typos)
happett- New Member
Number of posts: 24
Registration date: 2009-12-31
Ah... so NOW you know ha....
I am glad you find the Soulution/Magico sound 'supreme'. Why not ask Adrian for a suggestion for his best recommendation to meet your budget ? You must tell him that you are not uptight about new or used equipment, except that the system must sound good and the equipment in good condition lar.
WongKN- Moderator
Number of posts: 1747
You guys are real sifus in Kung Fu Hi Fi. Me own only one cheap US amp, a pair UK's vintage speaker and one Japanese cdp aslo already feel good. Everyday hear and hear... sleep... wakeup and here again.....
Amir- Regular
Number of posts: 68
Registration date: 2010-04-06
We are all still learning and sharing knowledge here..
There are even more enthusiasts who don't even bother to look at forums and just enjoy music at home.
Number of posts: 1025
Registration date: 2009-01-19
I attended my UTM lecturer class in acoustic engineering . he is the professor in acoustic engineering . Some criteria need take care for the good set up .
1. Your sound source . Eg : CD / DVD / Blu-ray was burn in wide musical freq range ?
2. Your hearing musical room space . How big was your room ?
3. Your room cure with RT60 ? Was the RT60 spec meet ?
4. Sound pollution . eg: near to the air port , construction , beside high way .
5. Acoustic material used in your room .
6. air gap in your room . eg: the door air gap , window air gap
7. your wall construction and door material need to know .
If you take care all of these items , You may not need spend too much money on your set up . I am sure will within your budget .
tanbotak- New Member
Number of posts: 8
Registration date: 2010-04-01
By fulfilling all the above-mentioned criteria, you might not have enough money left to buy the rest of the equipments.
Source(s): Digital
Speakers: Bookshelf
arremie- Frequent Contributor
Number of posts: 411
Registration date: 2009-02-09
Source(s): CD or Lossless
Amplification: Tube
Speakers: Loth
...until the end of my life, i couldnt afford the RM100k's system ... The RM1.5k it enough to bring happiness for me... Heh heh...
Amir- Regular
Number of posts: 68
Yesterday, I bought a CD to test out hifi systems. A Tsai Chin Test Machine CD, which was strangely reddish orange in colour. It is not like any CD I have ever seen, and I have initial problems to use EAC to make a copy of it onto hard disk. The CD seems to have very good soundstage and clarity ( is it XRCD?? not sure) . Another good CD to test is the Erich Kunzel's Round up or Time Warp.. ( I have the Round Up but not the Time Warp)..
Now can use it test out some more systems...
happett- New Member
Number of posts: 24
The most expensive CD I have is Jeniffer Warnes - The Hunter. It's called LPCD45 which I bought out of curiosity. The printed surface has been made to interestingly looks like vinyl. The data surface is dark purple. I'm not familiar with the songs so I can't tell whether it's better than normal print or not.
Maybe I need to get HDCD titles which I'm very familiar with such as Eagles or Aaron Neville. The question now is do they really worth the extra price.
Amplification: Tube
Speakers: Loth
arremie,
Do you mean XRCD titles?
There are lots of China made HDCD at music stores nowadays.
I have never tried them before. So, cannot comment much... hahahahaha..
I only have the normal version of The Hunter.
Yup those XRCD/HDCD around RM120 per CD. Wonder if they worth it. I saw a lot from HK. Even my LPCD also from there. Anyway I have to admit I like the only LPCD I have. It sounded so relax. Solid bass, clear sounding, good timbre and not too forward sounding vocal. Need to borrow normal version and compare to be very sure.
Amplification: Tube
Speakers: Loth
Hugo audiophile CD no.14 comes in a LPCD1630 together with a redbook CD for easy comparison. U may want to ask your regular CD shop if they have it.
Uncle Vic! many thanks for letting me have a listen to your setup! I am thoroughly impressed with your capability to create a system in a listening room that can give a sound stage where I can actually feel that I am in a big orchestra hall or a small one depending on the CD sounds.
How on earth did you manage to get the musical bass under control with your SIX (6) sub-woofers is a bit beyond me. With 4 other speakers together with Ribbon tweeters, the sound generated is quite magical.
But I am sure glad I got to know you. Basically I found that all of my CDs sound so much different on your system. Can hear the details and timbre so clearly. And thanks for giving me a lesson on listening skills!
I think the sound that can be closest to yours would be the Magico speakers with Soulution amp that I heard.
Last edited by happett on Fri Apr 16, 2010 2:03 pm; edited 1 time in total (Reason for editing : additions)
happett- New Member
Number of posts: 24
Happett, U are welcome. Glad u enjoy the listen session.
Wah Liao! U are not serous are u? The Magico & Soul-Lution combi?
Nearly 'pengsan' on reading this!
arremie wrote:The most expensive CD I have is Jeniffer Warnes - The Hunter. It's called LPCD45 which I bought out of curiosity. The printed surface has been made to interestingly looks like vinyl. The data surface is dark purple. I'm not familiar with the songs so I can't tell whether it's better than normal print or not.
LPCD45 are all CDR media, may be unplayable on some CDP's that weren't designed for CDR. However there's a cheaper Hugo made LPCD trademarked as LPCD 1630, which looks like normal aluminum press and likely no problem with any CDP.
Eagles or AN in HDCD?..
cmboy- Frequent Contributor
Number of posts: 1138
Registration date: 2009-03-11
The bass reproduction on Uncle Vic's system can even match Wilson Watt Puppy leh.
joydivision- Frequent Contributor
Number of posts: 233
Registration date: 2009-05-10
With 6 subwoffer, can even break the house....
Eagles or AN in HDCD?..Those 2 are available in XRCD albums. They're mastered to sound more dynamic.
Yeah I saw Eagle XRCD. Is it a definite improvement worth the price or just subtle. So far I never encounter any LPCD 1630 or maybe I wasn't paying attention because of the price
Amplification: Tube
Speakers: Loth
Somebody selling Harbeth HL5 at reasonable price today, very unlucky I just upgrade my speaker form Sonus Faber to Dynaudio. If not I may be grab this Harbeth. I like HL5 compare than new SHL5. Who are the lucky owner?
jemmi- Frequent Contributor
Number of posts: 184
Jemmi,
If u like the hl5 so much why not trade your dynaudio for a pair of HL5?
as long as u like it n no regrate
My whole system already upgrade to match with Dynaudio speaker. Can't afford to invest another maching system for Harbeth speaker. My target for Harbeth HL5 is Quad CDP + Quad Pre + Quad Power & full set Artisan cable (http://www.artisansilvercables.com/). I also like my current Dynaudio system very much, that's me always appreciate what I have. Hi hi hi (syok sendiri)...
Page 3 of 3 •
1, 2, 3
Similar topics» [request] simple "pass" or "technique" interface for rendering...
» (April 02, 2009) R.I.P. Caitlin "Kitty" Thomas <3
» Katia Zygouli : magazine "Diva"
» BHP is moving to "www.bravehalfling.com"
» HoDD's "skeleton"
» HoDD's "skeleton"
Page 3 of 3
» Marantz SR8002 7.1AV Reciever (Used)
» Monitor Audio BX6 and BX center (Used)
» FS : Krell FPB300cx power amp (used)
» Proceed DAC
» Usher Speaker
» FS ~ Assorted USA Made LPs
» Pro-Ject Tube Box II Phono tube pre-amp (Used)
» Linn LP12 - Turntable (Used)
» Speaker cable = theory or mitos
