QUAD 66 Pre-Amplifier England
Post by HiFiLab on Mon Dec 07, 2015 9:13 am
Made in Huntingdon, England.
QUAD 66
7-input Remote Control Pre-amplifier
The Quad 66 is a “high-quality preamplifier” system with full remote control operation.
It comprises two units -- (1) a mains operated pre-amp to which the various sound sources are connected; and (2) a separate battery operated control panel incorporating all the main function controls for operating the pre-amp and Quad CD player, or any other remote control CD player using the same remote control language.
If the battery fails the control panel can be directly powered from the pre-amp. A display on the main unit shows all functions selected.
The unit will accept inputs from seven sources -- Disc, CD Radio, AV, Aux 1, Aux 2 and Tape (with off tape monitoring).
A second tape recorder may be connected to the Aux 2 input and both the AV and Aux 1 inputs have anti hum-loop circuitry.
The control panel has rotary volume and balance adjustment plus press buttons for Disc, CD play, Radio, AV, Aux 1 and 2, Tape, Tilt (2), Bass Step (2), Filter (2), Cancel, Standby, Search (2), Track, Pause, Stop and Store.
The standby facility enables the Quad 66, and any other equipment connected to the AC auxiliary outlet, to be switched ON and OFF via the remote control panel.
SPECIFICATIONS :
Frequency response: 15Hz to 20kHz
Total harmonic distortion: 0.05%
Input sensitivity: 3mV (MM), 300mV (line)
Signal to noise ratio: 74dB (MM), 93dB (line)
Output: 300mV (line), 0.5V (Pre out)
Dimensions: 321 x 80 x 255mm
Weight: 3.3kg
In Good Working Condition Very Happy
Price : RM 2350
HiFiLab
Number of posts : 2067
BUMP
Post by HiFiLab on Thu Sep 07, 2017 7:14 pm
Up
HiFiLab
