EMOTIVA XPA-3 Three Channel Power Amplifier (Used) - SOLD
I'm selling my one month old Emotiva XPA-3 power amp bought directly from US.
This is a 3 channel power amp with 200W pure power per channel.
It comes with auto sensing power supply so it will accept our 240v AC. No need for stepdown transformer.
The 12v trigger works flawlessly so it will auto ON/OFF itself when you switch ON/OFF your AVR.
Condition: 9/10 (comes with double box, manual and even the plastic wrapper)
Contact: SMS 012-2959195 / Remy
Price: SOLD
SELF COLLECT ONLY as this unit is heavy (30kg).
I will also throw in 3 x 1m Emotiva Ultra RCA cables for free (this cable bought separately and not included with XPA-3)
SPECS:
Number of Channels: 3
Topology: Fully Discrete, Dual Differential, High Current, Short Signal Path Class A/B
Power output (all channels driven):
300 watts RMS @ 4 ohm (0.1% THD) per channel
200 watts RMS @ 8 ohm (0.1% THD) per channel
Power Band Response: 20 Hz to 20 kHz with less than .05db deviation at rated power
Broadband Frequency Response: (-3db): 5Hz to 150kHz
Amplifier Gain: 32db
Signal to Noise Ratio
1 watt: <98db
Full Power: <112db
Input Impedance:
Unbalanced – 47kohms
Balanced – 33kohm
Transformer Size: 850VA
Secondary capacitance: 60,000uF
Output Devices: 6 per channel
Size: 17” W x 7.75” H x 19” D
Weight: 57 lbs (72 lbs boxed)
FEATURES:
• Fully protected from all fault conditions
• Soft start circuitry
• External trigger turn on
• Soft touch power switch
• 4RU chassis w/ solid milled aluminum faceplate
• IEC power inlet, 120/230 VAC configurable
• Output design: Triple Darlington with On output stages
• Differential Drive: Dual Differential input
• Types of inputs: Balanced (XLR) and Un-balanced (RCA)
• Type of outputs: Audiophile quality 5 way binding post
• Display type: Digital status indicators
Price: SOLD
SPECS:
1 watt: <98db
Full Power: <112db
Input Impedance:
Balanced – 33kohm
FEATURES:
arremie- Frequent Contributor
- Number of posts : 533
Registration date : 2009-02-09
Source(s): Oppo
Amplification: Parasound
Speakers: Klipsch
» Emotiva XPA-3 3-Channel Power Amplifier [SOLD]
» Emotiva UPA-7 Seven Channel Power Amplifier [SOLD]
» Emotiva XPA-5 Five Channel Power Amplifier [SOLD]
