Speaker cable upgrade
Page 1 of 1 • Share •
Since cables are such hot topic let me stir up the hornets nest. Any suggestion for my speaker upgrade? I'm currently running "chicken wire" QED Silver Anniversarry XTs on my Audiophysic Scorpio. Amp is Primare I30 while CDP is Rega Saturn. All other cables are Siltech Classic Anniversary series. Would've been interested to try Siltech for speaker too but way above my max budget of ~MYR 3K. I need ~5m run per side. Heard the Clearaudio Clearline does wonders. Anyone here running the Clearaudio?
llsaw- Frequent Contributor
Number of posts: 441
Registration date: 2009-01-20
Source(s): Ayon Audio CD-1S
Amplification: Primare I30
Re: Speaker cable upgrade
llsaw wrote:Since cables are such hot topic let me stir up the hornets nest. Any suggestion for my speaker upgrade? I'm currently running "chicken wire" QED Silver Anniversarry XTs on my Audiophysic Scorpio. Amp is Primare I30 while CDP is Rega Saturn. All other cables are Siltech Classic Anniversary series. Would've been interested to try Siltech for speaker too but way above my max budget of ~MYR 3K. I need ~5m run per side. Heard the Clearaudio Clearline does wonders. Anyone here running the Clearaudio?
llsaw,
~5m run per side??? equal to 16ft-4inches per side??? must be joking???
if i were you stick back your QED. Clearaudio Clearline can't do the wonders at 5m. there are alot of sifu here can do the calculation for cables signal drop. please check.
happy listening.
alex_kff- Club Member
Number of posts: 42
Registration date: 2009-01-19
alex_kff wrote:llsaw wrote:Since cables are such hot topic let me stir up the hornets nest. Any suggestion for my speaker upgrade? I'm currently running "chicken wire" QED Silver Anniversarry XTs on my Audiophysic Scorpio. Amp is Primare I30 while CDP is Rega Saturn. All other cables are Siltech Classic Anniversary series. Would've been interested to try Siltech for speaker too but way above my max budget of ~MYR 3K. I need ~5m run per side. Heard the Clearaudio Clearline does wonders. Anyone here running the Clearaudio?
llsaw,
if i were you stick back your QED. Clearaudio Clearline can't do the wonders at 5m. there are alot of sifu here can do the calculation for cables signal drop. please check.![]()
happy listening.
Yes 5m per side. Have scheduled for a home audition of the Clearline. Will report if there's an improvement.
I'm currently running a personal comparo, nothing serious, just out of curiosity since cuti-cuti Chritsmas/End-year. of speakers cables that I have, some using some idling:
1. Transparent Musicwave 4 m (from hf4s)
2. Kimber 12 TC 1.8 m
3. Synergistic Research Signature 10 (w Active Shielding) 2 m
4. Audio Art SC5 1.8 m (from hf4s)
3. Vdh (not sure the model) 2.5 m
5. Ixos (not sure model too) 2.5 m
Based on what I heard, the Transparent and Synergistic Sig 10 seems most satisfying overall with the Living Voice spkrs, the 12 TC sweetest with my Von Schweikert but unbearable (for me though) through the LV... The models from Audio Art, Vdh and Ixos are in a different league altogether (their higher end brethren may tell a different story). IMHO many variables still need to be taken into account but the cable length may not be the main factor in my system I suppose.
My two sens worth...
zeebee- Frequent Contributor
Number of posts: 321
Registration date: 2009-02-05
Thanks for the comparo Zee Bee. Yes, I do not think signal drop will be a major factor for 5m if at all..
I use Supra Ply3.4S, very nice detailed inexpensive cable, for my Technics system.
TNT AUdio, gave it a really nice review.
I got mine from Divine Audio in the UK, and also the Australia supplier of Supra 18/metre
SVI3206A- New Member
Number of posts: 13
Registration date: 2010-01-30
SVI3206A wrote:I use Supra Ply3.4S, very nice detailed inexpensive cable, for my Technics system.
Errrr.. I think Supra Ply 3.4 will be a lateral move rather than an upgrade. Thanks for the suggestion though..
Hi llsaw
no worries, very nice cable works wonders for me, but i would read reviews and stuff like that in deciding
Number of posts: 13
SVI3206A wrote:Hi llsawno worries, very nice cable works wonders for me, but i would read reviews and stuff like that in deciding
Actually a proper audition better still home audition is a must for me rather than reviews..
Yes, must be to able to judge the cable urself. For me i had to take a chance and go by reviews, i was lucky the cable turned out to my liking
Number of posts: 13
Hi WongKN,
Am currently home auditioning the Clearaudio Clearline. Too good, just too good! Sounds like I upgraded my already excellent Scorpios
Am outta words..
Hi SVI3206,
Which part of the UK are you from? I used to study @ Coventry U back in '96..
Hi Llsaw, iam from Australia, but i buy my stuff from the UK, sometimes is cheaper for me, that buying here.
Having a very cold winter in the UK!!
WongKN, the Clearaudio mains is a 5star winner with whathifi.
Number of posts: 13
SVI3206A wrote:Hi Llsaw, iam from Australia, but i buy my stuff from the UK, sometimes is cheaper for me, that buying here.Having a very cold winter in the UK!!
Ok... The Clearaudio speaker cable qualifies for 6 stars with my setup. Only problem is cost. > 535GBP (RM3K) for a 5metre pair..
Even more stars circling above my head after looking at the price.
But then.. there are many even more expensive cables out there.
So, start save up bit by bit for it lor..
Number of posts: 1056
wow, thats heaps of mooney
azri- Frequent Contributor
Number of posts: 1036
Registration date: 2009-01-21
llsaw wrote:SVI3206A wrote:Hi Llsaw, iam from Australia, but i buy my stuff from the UK, sometimes is cheaper for me, that buying here.Having a very cold winter in the UK!!
Dang expensive, i wanted the mains Clearer Audio but cost, so ended up with a mains filter. If the powercable is 5star so woudl the speaker cable be
Number of posts: 13
OK.. end of search. I bought the Clearlines.
SVI3206A,
Clearaudio <> Cleareraudio. Clearaudio is a German concern and its primary business is manufacturing fab turntables. Clearer Audio seems to be British and seems to be only involved in hi-fi cables.
SVI3206A,
Similar topics» Chord Odyssey 2 Speaker Cable
» DIY Silver Speaker Cable
» Speaker cable lengths does it matter?
» Speaker cable, differences – Have I been duped?
» Acoustic Revive solid core speaker cable review
» Arcam DV 88 DVD/CD player
» Denon AVR-1508 AV Receiver
» Pioneer A-9 [80s] used
» Usher Audio S520 speaker
» Harman Kardon AVR-80 [SOLD]
