Sherbourn PT-7030 AV Processor & Sherbourn PA 7-150 Multichannel Power Amplifier ( 7channel x 150w ) ( sold )
Now, outstanding video performance and exceptional audio sound quality come together in a cutting-edge product that’s ready for full HDMI 1.4a—and your legacy sources, too. A wide variety of customization options let you tailor the response of the PT-7030 for excellent performance in virtually any home. With a main zone and up to three additional zones, the PT-7030 is easily integrated into popular home control systems, as a “command center” for complex installations.
2 – HDMI 1.4 outputs (Output 1 is ARC and CEC enabled)
3 – zone video outputs (composite)
2 – composite video inputs
1 – composite video output
2 – component video inputs
1 – component video output
1 – Reference stereo audio input (balanced, stereo)
1 – 7.2 Balanced output (7 channels plus 2 subs)
1 – Tuner input (unbalanced, stereo)
6 – Line inputs (unbalanced, stereo)
1 – 7.2 unbalanced input (7 channels plus sub, unbalanced)
3 – zone audio outputs (unbalanced, stereo)
1 – audio out (mix out, unbalanced, stereo)
7 – digital audio inputs (4 - optical Toslink; 3 - coax)
1 – USB input
2 – digital audio outputs (1 - Toslink optiocal, 1 - coax)
6 - Trigger outputs (independently configurable)
2 – IR outputs; 4 – IR remote inputs
1 – RS-232 serial control input
- Condition like new 9/10
- AV Processor PT-7030 at rmsold
- Power amp PA 7-150 at rmsold
- Both at rmsold
- hp 0129551750
- Twin Cirrus® 32-bit dual-core DSP processors for true 192kHz performance
- Genesis® Torino high-performance video engine for true 10-bit processing
- DCDi Cinema® Format Conversion and Truelife™ video enhancer
- HDMI 1.4a Deep Color Compliant, ARC, CEC
- Discrete multichannel parametric EQ for precise room correction.
- Support DTS HD Master Audio and Dolby Digital Truehd surround format.
- Fully balanced 7.2 channel outputs and balanced outputs
- 3-zone, ethernet control and RS232 remote with extensive driver set
- Bluetooth wireless audio and iPod/iPad support
- Rack mount ears included
Features
- Six HDMI 1.4a inputs and two HDMI 1.4a outputs (one output is ARC enabled).
- Twin Cirrus® 32-bit dual-core DSP processors for true 192 kHz audio performance.
- Genesis® Torino high-performance video engine for true 10-bit video processing.
- DCDi Cinema®Format Conversion and Truelife™ video enhancer.
- Individual DACs and volume control circuits for each channel, and a very tightly regulated multi-stage linear power supply ensure the absolute best audio performance.
- HDMI 1.4a Deep Color Compliant.
- Configurable CEC participation (CEC can be limited to avoid conflicts).
- Full set of 7.2 balanced outputs and full set of 7.2 unbalanced outputs.
- Plenty of inputs for all your digital audio source components:
- (4 x digital Toslink, 3 x digital Coax).
- Plenty of inputs for all your analog audio source components:
- (one stereo pair of balanced inputs, seven stereo pairs of unbalanced inputs,
- one 7.2 channel set of unbalanced direct inputs).
- Three zones of stereo audio and composite video outputs ( in addition to the main zone).
- Component video inputs and outputs.
- Full integration with popular remote control and automation protocols.
- iPod/iPad support
Connectivity
6 – HDMI 1.4 inputs (all support 3D)2 – HDMI 1.4 outputs (Output 1 is ARC and CEC enabled)
1 – USB input
- Both at rmsold
- hp 0129551750
hamster2- Frequent Contributor
- Number of posts : 310
Registration date : 2010-05-25
» TagMclaren AvantGarde 7channel processor & 5channel power amplifier (SOLD)
» Tag Mclaren AV32R processor + 100x5R 5 channel power amplifier (sold)
» Acurus A150 Stereo Power Amplifier - 150W@8ohms
» Rotel Multichannel Power Amplifier
» Proceed Amp3 Power Amp ( 3 Channnel x 150W ) sold
