Rotel RQ-970BX MM & MC Phono Stage
Post by raymond88 on Sat Feb 13, 2016 3:08 pm
Item: Rotel RQ-970BX MM & MC Phono Stage
Condition: Item is in excellent tip top condition, inside and out.
This is a very nice sounding phono stage for the money.
With all Black Gate capacitors used for the power supply
and bypassing. With IEC conversion done.
Excellent rhythm and pace. Highs are perfect. Detail is superb.
Lows solid. No audible noise.
Price: RM680 or swap/topup
Some info:
Description
With the increased use of digitally based audio media, many modern high performance audio components lack the circuitry needed to handle the signals produced by phono systems.
The RQ-970BX is a high-performance phono equaliser, the output of which can be plugged straight into any line level input.
Using the same sophisticated circuit designs and high quality components that have made Rotel a world-wide standard of performance, the type of design used in the RQ-970BX is expensive to manufacture, but it is better for the music.
Total harmonic distortion: <0.004%
Intermodulation distortion: <0.004%
Input sensitivity: 210uV/100ohm (MC), 2.5mV/47kohm (MM)
Phono overload: 16mV (MC), 160mV (MM)
Output sensitivity: 150mV/100ohm
Frequency response: 20 to 20,000Hz
Signal to noise ratio: 70dB (MC), 75dB (MM)
Dimensions: 440 x 72 x 195mm
Weight: 3.1kg
Review
it's a no brainer for someone with a modest vinyl system who wants to keep it that way, financially speaking.
Websites:
http://www.soundstage.com/vinyl/vinyl200105.htm
http://www.vinylengine.com/library/rotel/rq-970bx.shtml
Thank you.
Number of posts : 3492
Re: Rotel RQ-970BX MM & MC Phono Stage
Post by raymond88 on Sat Feb 20, 2016 11:44 am
Post by raymond88 on Wed Sep 20, 2017 7:58 pm
Item is back for sale.
