GOLDRING NS-1500 (NOISE CANCELLING HEADPHONE)
Post by Richard@yew on Sat Apr 02, 2016 6:27 pm
The noise cancellation feature is rated at 89% reduction in linear noise pressure, 99% reduction in linear noise energy and up to 19dB logarithmic reduction in noise pressure. For those less technically inclined, just snap your fingers inches away from the ear cups with and without the noise cancellation on. Or turn them on when the missus is on the war path.
The headphones fit quite comfortably and the padded ear cups just about covered the pinnas and the pressure was not too uncomfortable.
The connector is a 3.5mm with a quarter-inch connector that fits over it. An airline adapter is also included along with a case.
Its rated frequency response is 20Hz to 20kHz and its impedence is 32Ohm which makes it easy to drive.
I used the headphones plugged into the laptop while I did my daily work.
Using J River v 17, I played hi-res 24/192 and 24/96 files. As reference, I used my son’s pair of Audio Technica headphones. After a while, I switched to listening to MP3 files on my HTC One smartphone.
From the outset, I have to state that the headphones sound better – and louder – with the noise cancellation switched on. Obviously I would recommend listening to music with the noise cancellation on all the time and turn the power off only when not in use. So if the battery runs out of power, replace it asap.
On the whole, the tonal balance is quite neutral. The bass is quite strong, the mids are smooth enough and the treble quite clear.
However, when compared with costlier headphones – I also used the resident Sennheiser HD600 – the transparency, space and soundstage size could be better. In comparison, the Goldring sounded a bit closed in.
Compared with another pair of headphones with active noise cancellation that I reviewed some time back – the Beats by Dr Dre Studio – the Goldring’s tonal balance is more neutral. If I recall correctly, the Dr Dre was rather bassy.
If you are in the market for headphones on the go – weighing  less than 180gms, the Goldring is meant for mobility – the NS1500 should be in the list for auditions. Its good noise cancellation feature adds to the value.
Price Before : RM990.00
   But NOW : RM490.00
Richard Yew (+016-62217099)
pls:whatsapp/sms
CMY Audio & Visual S/B
LG2.13,LOWER GROUND LEVEL2,SUNWAY PYRAMID SHOPPING MALL,
NO3,JALAN PJS 11/15,BANDAR SUNWAY,
46100,PETALING JAYA,SELANGOR,
MALAYSIA.
Richard@yew
Number of posts : 228
Registration date : 2016-03-30
