Mission M3 5.1 Speaker System (New)
Post by Richard@yew on Mon Apr 04, 2016 5:13 pm
ELEGANT YET COMPACT 5.1 SOUND
M³ is the third generation satellite and subwoofer 5.1 AV system from mission. M-Cube is now M Cubed.
M³ is designed specifically for fuss-free home cinema. Compact speakers, simple mounting brackets and wide dispersion audio means you can't go wrong from installation to enjoying a movie.
COMPACT FORM, MASSIVE COVERAGE
The M³ satellites sound clear wherever they are placed. The key to the M³s ability to provide high quality sound no matter where you sit is in the BMR driver technology.
Not only do they cover 120Hz to 20kHz frequency response and beyond, but it also disperses its output over an unprecedented 90 degree angle.
For a fast route to home cinema, the M³ is ready for easy-install. Out of the box, M³ satellites have compact stand mounts attached suitable for placing the unit on flat surfaces.
M³ is also supplied with brackets that can be mounted on the wall around your room. Installation couldn't be easier.
SUBWOOFER SPECIFICATIONS
  • Active closed box subwoofer system
  • 200mm long throw bass driver
  • 200mv input sensitivity
  • 400W peak power output
  • 108dB max spl
  • 35-120Hz frequency response (+/-3dB)
  • 30 Hz bass extension (-6dB)
  • 100-150 Hz crossover
  • Phase inversion
  • HP output
  • LP frequency adjust
  • (276+60) x 274 x (274+20)mm
  • 7.88kg
SATELLITE SPECIFICATIONS
  • Wideband bookshelf / surround speaker
  • Full range 3" BMR transducer
  • 40-80w reccomended amplifier power
  • 100dB peak SPL
  • 8 Ohms nominal impedance
  • 4.5 Ohms minimum impedance
  • 150 Hz - 20 kHz frequency response
  • 110Hz bass extension (-6dB)
  • (90+15) x 90 x (88+9)mm
  • 0.75kg
Selling Price : RM3,770.00 (Call For Best Price)
Richard Yew (+016-6217099)
pls:whatsapp/sms
CMY Audio & Visual S/B
LG2.13,LOWER GROUND LEVEL2,SUNWAY PYRAMID SHOPPING MALL,
NO3,JALAN PJS 11/15,BANDAR SUNWAY,
46100,PETALING JAYA,SELANGOR,
MALAYSIA.
Richard@yew
Number of posts : 228
Registration date : 2016-03-30
