Mission SX-1 (NEW)
Mission SX-1 (NEW)
Cabinet Construction
Sweeping curves across every cabinet surface are there for a reason. As well as hindering the production of internal standing waves, each cabinet is constructed from a precise formula of interleaving wood layers, glued and pressed at high temperature for 48 hours and then left to cool naturally so that internal stresses are eliminated. The result is a cabinet of acoustically inert properties – a perfect chassis for the working parts of the loudspeaker.
Drive Units
Some of the innovative improvements for SX Series include the composite alloy based diaphragms of the midrange and bass units which provide detailed sonic performance and extremely low distortion from the driver due to the stiffness of the material. The Mission TD treble unit dome is made of light but very rigid Titanium which reproduces high frequencies with astonishing clarity and purity. Integrated into the front of each cabinet is a die cast and precision engineered aluminium driver support baffle. This supports the high-tech drive units and keeps them in precise alignment as well as ensuring freedom from extraneous vibration. In addition the new Mission TD treble unit is mounted on its support to keep it free from the perturbations of mechanical energy imparted from the bass unit.
- Bookshelf / Standmount
- Bass reflex enclosure
- 2-way speakers
- 130mm aluminium cone woofer
- 25mm titanium dome tweeter
- 85dB sensitivity (1w @ 1m)
- 20-75W reccomended amp power
- 75W peak power output
- 100dB peak SPL
- 6-8 Ohms nominal impedance
- 3.9 Ohms minimum impedance
- 62Hz-42kHz frequency response
- 52Hz bass extension
- 2.2kHz crossover frequency
- 313 x 191 x 293mm
- 7kg
Selling Price : RM3,890.00 (Calling for Best Price)
Richard Yew (+016-6217099)
pls:whatsapp/sms
CMY Audio & Visual S/B
LG2.13,LOWER GROUND LEVEL2,SUNWAY PYRAMID SHOPPING MALL,
NO3,JALAN PJS 11/15,BANDAR SUNWAY,
46100,PETALING JAYA,SELANGOR,
MALAYSIA.
Richard@yew- Dealer\Reseller\Trader\Service Provider
- Number of posts : 228
Registration date : 2016-03-30
