DLS D3 Lifestyle Floorstand Speaker (Display Unit)
Post by Dicky Ng on Sun Apr 10, 2016 11:31 am
DLS D3 is a floor-standing loudspeaker designed for home theatre systems and hi-fi applications. The new edition has a cabinet in black satin finish (also available in white satin).
To satisfy our customers needs we have created a unique type of speaker in different colours to match the home environment.
D3 can be bought without the separate coloured side panels, if you prefer. But if you want something extra there are beautifully shaped side panels in five different colours. They are bought as separate accessories. The priority was to achieve ultimate sound quality with deep bass tones from a slim speaker design, just as for the T3 series.
The exceptional performance of this speaker is a result of advanced speaker-design skills and unique driver technology.
D3 uses the same "transmission line" technique as T3, but with a cabinet of MDF instead of aluminium.
Description / type2-way transmission line
Finish / colourblack
Impedance4 ohm
Sensitivity88 dB/1M, 1W
Frequency range48 Hz - 25 kHz
Recommended amplifier50-120 W
Woofer size3"
Midrange size3"
Tweeter28 mm soft dome
Crossover4200 Hz
Crossover point (Hz)4200 Hz
Dimension (W x D x H)123 x 230 x 1230 mm (4,8 x 9,0 x 48,8 inches)
Weight8,5 kg / 17,7 lbs
Condition : 8/10
Asking : (RM 3900RM 1900
Contact : Dicky Ng 012.330 8893
CMY Audio & Visual S/B
LG090, Lower Ground Floor,
Sungei Wang Plaza, 50250,
Kuala Lumpur.
Tel : +603-2143 9406
avatar
Dicky Ng
Number of posts : 559
http://www.cmy.com.my
