Blue Horizon Proburn Cable Burn In Machine - (Demo)
- High quality cable burn in device
- The Blue Horizon Proburn is a high quality, dedicated cable burn in machine that dramatically reduces the burn in time required by new cables to sound at their best, and also optimises the performance of existing cables to a level that music simply can't match
- You can use Proburn to burn in RCA interconnects, XLR interconnects or speaker cables.
- Cable burn-in is an acknowledged problem that was in need of a better solution. The problem is straightforward. Real music has relatively little high-frequency energy, and thus has a limited ability to improve a cable
- Research shows that musical instruments may produce energy above 20kHz, but there is little sound energy above 40kHz. Also, most microphones do not pick up sound at frequencies much higher than 20kHz.
Selling Price : RM 3,850.00
Steve Chua (+6012.653.5703)
Jeremy Khor (+6010.374.7819)
CMY Audio & Visual S/B
Malaysia.
Tel : +603-7726 6893
Fax : +603-7726 6893
» Blue Horizon Clean IT ( Connector Cleaner )
» Blue Horizon Pro Burn ( Cable Run In )
» BlueHorizon Proburn Cable Burn-in / Conditioner (New)
» Blue Horizon Clean-IT Contact Conditioner (New)
» Blue Horizon Clean It Solution (New)
