Mission 796SE Floorstand Speaker (New)
Mission 796SE speakers are the latest sonically enhanced (SE) version of the stunning Mission 796 speakers, offering a quality of sound, finish and design true to Mission's iconic heritage, in a beautifully lacquered piano black finish. Sonic enhancements include new silk dome tweeters mounted on a die-cast waveguide to improve sound dispersion and midrange integration with the bass-mid unit.
The 796SE are part of the new 79 series from Mission, designed with curved cabinets to achieve a synergy between drive units, cabinets and intended frequency responses. As a result, only simple crossovers are required, using high quality components to maintain signal purity.
The speaker cabinets are composed from a multi-layer construction with different densities of resonant absorbing particle composite. These layers are laminated with RF activated resin to provide further isolation of vibration and prevent layer interaction. Each layer is tuned to damp different frequencies of resonance, combined to reduce lateral and longtitudinal vibration transmissions.
An impressive example of modern design combined with powerful performance. Use these speakers for stereo music, or match them with the Mission 790SE, Mission 792SE, Mission 794SE and/or Mission 79C SE centre speaker for a stunning home cinema sound set-up.
- Enclosure type: 3-way reflex
- Driver units: Bass 200mm, Bass/Mid-range 165mm, Tweeter 25mm
- Frequency response +/- 3dB: 38Hz - 20kHz
- Sensitivity SPL/M @ 2.83V: 90 dB
- Nominal impedance: 8 Ohms
- Recommended amplifier power: 50 - 200W
- Dimensions (mm): 998H x 206W x 318D (each)
- Weight (kg): 25.2 (each)
Selling Price : RM9,400.00 (Call For Best Price)
Steve Chua (+6012.653.5703)
Jeremy Khor (+6010.374.7819)
CMY Audio & Visual S/B
Malaysia.
Tel : +603-7726 6893
Fax : +603-7726 6893
» Mission 796SE Floorstand speaker (sold)
» Mission 796SE Floorstand Loudspeaker (New)
» Mission VX-3 Floorstand Speaker
» Mission E83 ( FloorStand Speaker )
» Mission SX-5 ( Floorstand Speaker )
