Audio Pro WF-100 Wireless Transmitter & Receiver (New)
Post by steve126 on Tue Apr 19, 2016 5:17 pm
All of us dream about an easier life. When we created the Audio Pro Wireless solution, our goal was to eliminate loudspeaker cables and keep high quality hi-fi sound, so you could enjoy great sounding music anywhere in the home without the clutter. WF100 brings the dream alive in the shape of a small dongle.
The WF100 dongle set is the easiest way to establish a robust and fast wireless network with CD quality streaming. And it works both on a Mac and a PC without complicated installation or software download.
The flexibility of this dream system allows you to add as many receivers as you like in your home (within range of transmitter) in order to create a multiroom sound experience that’s easy and cable-free.
What’s more, built into this miraculous design is a way to let you connect any device with sound input/output to our wireless audio streaming network. This is all achieved without delays and interference but with lots of fun and satisfaction.
Listening To The Revolution
If you understand just how radically people have changed their listening behaviour, you can be part of the revolution. Audio Pro is one the first specialised audio designers to support the movement from CD as a source to hard drive. If you use a computer or handheld device as your music player, we want you to enjoy the best quality sound in the easiest way possible via a reliable wireless connection. No cables. No fuss. High quality. Reliability. We embrace the revolution. Do you?
It's As Easy As Counting To Three
We design our products to be very easy to use. That's why our speakers need only power; our wireless units need no software and our transmitter only a sound source. Connect the speakers to power, connect the transmitter to your computer (or other device) and play your music. It's as simple as that!
Unique Network For Best Quality
Audio Pro Network uses a dedicated, protected protocol which is in 2.4 GHz-band for best possible sound quality. The transmission is in full CD quality which makes it possible to play uncompressed formats such as FLAC, Apple Lossless etc. We have a built-in “sniffer” system to sniff out any other wireless channels which may potentially give interference. This “sniffer” system automatically jumps between free RF(Radio Frequency) channels so no interference will occur. Using frequency hopping before listening, the system switch channel before any interference occurs. The system progressively control our audio bands. This ensures that the Audio Pro network work and coexist with other wireless systems. We have a built-in security that filters RF interference from other wireless networks.
Music In More Rooms,Just Add Receivers
You can add more RX100 receivers to each House Code as long as receiver are within range of transmitter. Add more stereos, radios and powered speakers to the wireless audio network without problems. Single RX100 units are available separately.
Multiroom Made Simple
With our House Codes you can have up to three separate audio networks in your home. Using three different transmitters you can listen to different muisc in different rooms at the same time. Each receiving device, such as Living speakers and WF100, has a switch for which House Code it should use. And you can easily change to have all on same House Code, letting all devices play from one sound source.
Play From Your Ipad / Iphone / Ipod Touch
With Apple AirPlay and Audio Pro Wireless you can stream iTunes playlists and songs from your Mac, iPad and iPhone wirelessly to Living speakers or RX100 receivers anywhere in your home. Just connect our transmitter to an Airport Express (transmitter must be powered separately by the CPS008 USB power adaptor) and select your Airport Express unit as sound device on your iPad, iPhone or iPod Touch. Now let the music flow.
Spashtop Remote:Mirror Your Computer On Your Ipad
With Splashtop Remote you can access everything on your computer via your iPad: watch videos, work in Word or listen to your music. Splashtop works brilliantly with Audio Pro Wireless to make your iPad a great remote for your music. Just connect our transmitter to the computer you mirror with Splashtop and access your music wirelessly – as well as everything else on your computer. You’ll find Splashtop Remote in the App store.
Works With All Music Players
Advanced Technology Built-In
Audio Pro always uses the most advanced and proven technologies to give you the quality you expect from us. For our wireless components we’ve installed high performance Burr/Brown D/A-converters with 24 bit resolution and advanced Sonix digital sound processors, which use superior noise reduction and sophisticated error correction algorithms for best possible sound reproduction and extremely high efficiency.
Wireless Audio From Whatever You Like
Our flexible wireless transmitter makes it possible to connect to any soundsource. You can connect it directly to your computers USB port or to your stereo or iPod-, iPhone- and iPad-dock via 3.5 mm stereo cable. Done! Now you can enjoy perfect wireless sound. You can connect any soundsoruce which has a sound output (such as headphones out) to the transmitter, and all powered speakers which has line in to the receiver (separate USB powersupply is needed if the unit doesn't have USB power supply.)
Selling Price : RM1,120.00
Offer Price    : RM750.00 (Limited Stock)
Steve Chua   (+6012.653.5703)
Jeremy Khor (+6010.374.7819)
CMY Audio & Visual S/B
Malaysia.
Email :     [You must be registered and logged in to see this link.]
Website : [You must be registered and logged in to see this link.]
Tel :  +603-7726 6893
Fax : +603-7726 6893
avatar
steve126
Number of posts : 373
http://www.cmy.com.my
