Wadia a102 Stereo Power
Post by avresearch on Wed May 25, 2016 7:20 pm
Wadia's compact a102 power amp delivers plenty of clean, accurate power to drive a high-quality two-channel audio system. It kicks out 50 watts per channel into eight ohms, and can increase its output at four ohms to deliver 80 watts per side. That's enough to push most speakers with ease, and it's ideal for today's high-end speakers, which often run closer to 4 ohms than 8.
Product Highlights:
  • 2-channel power amplifier
  • power output: 50 watts x 2 into 8 ohms, 80 watts x 2 into 4 ohms
  • frequency response: 10-50,000 Hz (+0 dB, -3 dB)
  • total harmonic distortion: 0.2% up to half rated output, 0.5% up to full rated output (20-20,000 Hz)
  • signal-to-noise ratio: 96 dB (113 dB below rated output) balanced, 93 dB (110 dB below rated output) unbalanced
  • electronic switching amplifier design for cool, efficient operation
  • Signal Surveyorâ„¢ technology monitors amplifier output to protect speakers from potential damage
  • one RCA and one XLR input for each channel
  • gold-plated binding post speaker terminals
  • defeatable auto-standby mode detects incoming audio signals for easy integration with a preamp
  • DC trigger input/output
  • detachable powercord
  • 10"W x 3-3/16"H x 14"D
  • weight: 8.5 lbs.
Now offer for RM 6,999
Available In AV Research
Wisma MPL, Jalan Raja Chulan
For more info, pls call Cheong o123o63455
avresearch
Number of posts : 3
Registration date : 2016-05-24
