Rogers High Fidelity 34S-1
Post by Audioline on Wed Jun 22, 2016 10:50 pm
- Von Schweikert Audio
- PureAudio
- KR Audio
- TriangleART Turntable
- Endeavoraudio Audio
- Graham Audio
- Ensemble Audio
- First Sound Audio
- Rogers High Fidelity
- Sutherland (Phono Preamplifer)
- Audiodesk Vinyl Cleaner
- Artesania Audio (Rack)
- Zontek (Turntable / Tonearm / Phono Preamplifier)
- Mutech (Cartridge)
- Audio-Technica (Cartridge)
- The Wand (Tonearm)
- Glanz (Tonearm)
- Abis (Tonearm)
- ViV Laboratory Rigid Float Tonearm
Retail Price: SGD$26000.00
Powered by eight EL-34 analog vacuum tubes, the 34S-1 integrated amplifier delivers monster performance and a dazzling listening experience. Consistent with Rogers High Fidelity’s gold-standard requirements, this Class A integrated Amplifier boasts superior precision, aerospace engineering and hand-made craftsmanship that presents a new level of realism in audio reproduction.
The ultimate control application easily integrates Apple® iOS® and Android™ devices with the Rogers High Fidelity Control System to monitor tube status and control all amplifier functions.
Made In The USA
Hand built to the most exacting specifications in our New York Facility. All amplifiers are fully evaluated and acceptance tested using the the best audio test equipment made by Audio Precision. We perform all of the tests in a typical Stereophile test evaluation and many more to characterize each amplifier. Each amplifier is shipped with a fully evaluated test data package so that the customer can see how his particular unit performed after acceptance.
Eight EL-34 Tubes
Four, for each channel and eight total for stereo operation following a true dual mono design.
Completely Hand Wired
The entire amplifier is wired by hand using all American labor in NY. The wiring is all discrete components and all point to point. This provides a lifetime of serviceability and reliability. All of the wiring and soldering meets the Military Standard 2000 requirements. All operators are trained to this standard.
Class A Operation
Military specification components, point to point Teflon wiring all carefully manufactured to the highest specifications.
Control Capability via Bluetooth
Connection to both Apple and Android smartphone applications the 34S-1 displays on application control functions of all the amplifiers features: Ultra-linear and triode modes, Volume, Input and the Status of the power tubes in real time operation using visual indicators.
Dual Power Supply Circuit
Can easily handle large dynamic transitions in the audio signal being delivered while maintaining a smooth and clear midrange; vocals are presented with a truly rich and warm feel.
Auto Bias Circuit
For long tube life and ease of operation. Self Bias circuit for adjustment free operation and longest tube life. Customer does not need to adjust tube bias. As the tubes age, they adjust for bias changes automatically. The customer can change tubes at any time or replace a single tube rather than the full set of 4 and the amp will automatically re-bias for the change.
Manufacturing Process
All amplifiers are built using our own Statistical Process Control manufacturing processes that yield better than a 99.8% first pass yield. This is better than the airline industry’s or hospitals’ safety record. The finished amplifier is 100% reliable, tested and guaranteed for a lifetime.
Aviation Grade Chassis
All amplifier chassis are aviation grade aluminum with a mutiphase powdercoat and clear coat finish. The amplifier finish is absolutely beautiful and bulletproof! The front panels are machined from solid blocks of aviation grade aluminum. The entire amplifier is assembled using Military Standard stainless steel hardware for ultimate reliability and a lifetime of trouble free service. All hardware is meticulously staked using an aerospace coating to eliminate any hardware failures over time through vibration, shipping or movement. This is an assembly process honed over many years of satellite manufacturing and assembly where re-tightening hardware can’t happen.
Aerospace Specifications
All of our resistors, capacitors, transformers and inductive components meet or exceed the applicable military quality standards for parts selection. We use the same parts used by NASA in the Shuttle and Space Station equipment.
Burn-In Process
Each amplifier undergoes a rigorous 100 hour burn-in prior to acceptance testing. This drives out any component infant mortality problems and ages each amplifier into it’s perfect listening range.
Power Measurement System
Each amplifier has a tuned, power measurement system that allows for flawless system integration and adjustment.
Binding Posts
We use Furutech binding posts for all amplifier designs. These are solid copper posts milled from OFC copper billets and then Rhodium plated with carbon fiber insulators. They are simply the best the industry has to offer. All inputs are gold plated RCA connectors.
Internal Wiring
The entire amplifier is wired using 18 gauge Military Standard 16878 teflon coated, silverplated copper wire. This is the same wire used for the Navy’s Aegis Cruisers! Heat is the enemy of amplifier reliability. Because this is a Class A design, there is some heating of the unit which causes the wiring to age and degrade over time. Our wire never ages. The teflon coating will last a lifetime. The interior of your amplifier will look the same in 10 years as it looks coming off of the production line. The amplifier is designed using all 18 gauge wire to provide many times more the current density than can be achieved using printed wire boards or lower quality wiring.
The 34S-1 provides state of the art noise and distortion performance using all Teflon wiring and mil spec components. Another bonus feature is the isolation of each audio channel using a dual power supply design and a dual mono circuit point to point design. Even the most critical of listeners of the 34S-1 will enjoy the finest, organic tube sound quality with stunning three-dimensionality, low-level detail-retrieval and holographic sound staging.
1 Orchid Club Road,
Social Clubhouse Unit #02-33B,
Orchid Country Club
Singapore 769162
Feeder bus every 15 mins from yishun mrt at taxi stand area
Whatsapp / Line +65 98353600
Sunday & Monday       1200 HRS to 1700 HRS
Tuesday to Saturday   1200 HRS to 1800 HRS
Number of posts : 308
Registration date : 2010-01-23
