Audio Desk Systeme Vinyl Pro
Post by Audioline on Wed Jun 22, 2016 10:55 pm
- Von Schweikert Audio
- PureAudio
- KR Audio
- TriangleART Turntable
- Endeavoraudio Audio
- Graham Audio
- Ensemble Audio
- First Sound Audio
- Rogers High Fidelity
- Sutherland (Phono Preamplifer)
- Audiodesk Vinyl Cleaner
- Artesania Audio (Rack)
- Zontek (Turntable / Tonearm / Phono Preamplifier)
- Mutech (Cartridge)
- Audio-Technica (Cartridge)
- The Wand (Tonearm)
- Glanz (Tonearm)
- Abis (Tonearm)
- ViV Laboratory Rigid Float Tonearm
AUDIO DESK SYSTEME VINYL CLEANER PRO (RECORD CLEANING MACHINE)
Recommended Retail Price: SGD$4500.00
Audiodesk Systeme Vinyl Pro Cleaner
Since January 2016 the Vinyl Cleaner PRO Includes improvements in the drying process, better water drainage and other improvements.
The Audio Desk Systeme Vinyl Pro Cleaner is an LP cleaning machine that incorporates an ultrasonic cleaning cycle in addition to a more conventional mechanical cleaning via bi-directional rotating microfiber cleaning drums, and the result is the cleanest LP's ever. Unlike other record cleaners the ultrasonic Vinyl Cleaner bursts millions of microscopic bubbles off the surface of the record all the way to the bottom of the groove, where no fiber is fine enough to reach. Among vinyl cleaners the Audio Desk System Vinyl Cleaner is unique in using filtered air for drying, rather than one of the static-inducing suction systems employed by other vinyl cleaning products.
This vinyl record cleaner is fully automatic - just put the LP in the slot, push the button, and come back in 6 minutes (or tomorrow!) for a thoroughly cleaned and dried LP (both sides). Whole new layers of inner detail and air are revealed in the recordings, and of course most surface noise is eliminated.
Comes with 2 vials of a proprietary cleaning fluid developed specifically for this machine. A container of the fluid concentrate plus a gallon of distilled water cleans 150 new LP's, or 100 used LP's.
TECHNICAL: HOW CAN SOUND CLEAN?
A physical effect called "cavitation" results from the generation of ultrasonic frequencies in a liquid. In this cavitation process ultrasonic "compression waves" are created by an ultrasonic transducer. When the amplitude of this soundwave increases to a level where the surface tension of the liquid is broken, the fluid will "tear" apart leaving behind millions of microscopic vacuum bubbles. These vacuum bubbles then rapidly compress or implode creating millions of tiny liquid jets small enough to clean inside the smallest grooves of an LP. This process, also called "microagitation," displaces any contaminants on the surface of the LP.
FEATURES:
- Cleaning cycle: 5 minutes
- Dimensions: 33cm wide x 20cm deep x 27cm high
- Weight (empty): 5,5 kg
- Water capacity: 4,5 Litres, cleaning concentrate 20 ml
1 Orchid Club Road,
Social Clubhouse Unit #02-33B,
Orchid Country Club
Singapore 769162
Feeder bus every 15 mins from yishun mrt at taxi stand area
Whatsapp / Line +65 98353600
Sunday & Monday       1200 HRS to 1700 HRS
Tuesday to Saturday   1200 HRS to 1800 HRS
Audioline
Number of posts : 308
Registration date : 2010-01-23
http://www.audioline.com.sg
