Copland CTA10 Pre Amplifier and CTA504 Power Amplifier (Sold)
Hi,
I am posting on behalf of a friend, who has the following items for sale.
Item
One unit of Copland CTA10 Pre Amplifier, equipped with 4 x 12AX7 tubes.
One unit of Copland CTA504 Power Amplifier, equipped with 4 x 6550 tubes (replaceable with KT88 tubes), and 4 x 12AX7 tubes.
Both items are in immaculate condition, conservatively rated at 8/10. No packaging.
Some details from the net:
The Copland CTA 504 is of Danish design that brings joy to their owners who wish to listen to music, rather than "high fidelity". This high quality, effortless and natural sounding amplifier invites disk after disk, bringing out the essence in music. The current supply circuit is classified into seven lines, was protected by the respectively quality film capacitor, and has controlled the mutual intervention also in the super-high region. The condenser which fully took the special order toroidal transformer and proof-pressure margin of the tanker cage is adopted as a power-source part. Although the output power is driven by 6550A tubes, the phase inversion circuit of the push pull composition using two for a Twin Triode is adopted. That means this amplifier is pentode and triode switchable. Triode Mode gives the listener all the classic, free-spirited openness that SET amplifiers are famous for, with a vibrant presentation and plenty of the coveted "triode cream." The sound is intimate, honest, and natural, with a captivating musicality that holds the listener in his listening chair and won't let him go. Acoustic music in Triode Mode produces off-the-scale "goosebump factor." The extreme realism of strings and wind or brass instruments will send chills down his spine. Triode Mode also excels in the reproduction of female voice with fluidity and realism, which is a very difficult test for any amplifier. With twice the power of Triode Mode, Pentode Mode turns up the heat with speed and slam galore. While Triode Mode is generally preferred for most acoustic music, Pentode Mode works well for many types of electric music. The slap of kick drums, the crack of snares, and the attack of percussion in general is noticeably presented differently.
Specifications :
Form.......................................................Tube power amplifier
Effective output.........................................At the time of pentode connection: 50W+50W
.........................................At the time of triode connection: 26W+26W
THD.........................................................Below 0.08% (1kHz/1W)
.........................................................Below 1% (1kHz/50W)
Frequency response..................................5Hz - -65kHz three dB
Output bandwidth......................................8Hz - -45kHz three dB
Signal to noise ratio...................................100dB (IHF / input short-circuit)
Input sensitivity.........................................1.5V
Input impedance........................................250kohm
Output load impedance..............................4ohm or Eight ohms
..............................(minus community, plus connection substitute)
Negative feedback.....................................16dB
The phase between input and output............Right phase
Valves employed.......................................Voltage magnification and phase inversion: E83CC x 5
.......................................Electric-power magnification: 6550 x 4
Power consumption...................................185W (Electrical Appliance and Material Control Law)
Dimensions(w x d x h)................................43 x 44 x 17.5 cm
Weight......................................................20 kg
Miscellaneous :
Made in.....................................................Design in Denmark
http://audio-database.com/COPLAND/amp/cta504-e.html
Apologies, not much information available on the CTA 10.
Price
Selling as a set for RM Sold.
Dealing Method:
COD Shah Alam, Selangor.
Contact Details:
Please contact James if you are agreeable with the price. James can be reached at 017 313 1988. Due to work commitments please leave a message and a contact number if you are unable to reach him, he will contact you as soon as he is available.
Pictures
Thank you for viewing my post.
Item
Specifications :
Miscellaneous :
Price
Dealing Method:
Contact Details:
Pictures
Last edited by gkt on Sat Sep 10, 2016 6:50 pm; edited 2 times in total (Reason for editing : Price adjustment; Sold Thank you)
gkt- Frequent Contributor
- Number of posts : 502
Registration date : 2013-11-15
Source(s): Densen B475, Goldmund Mimesis 12 DAC
Amplification: Clarity Audio Mono Pre and Power
Speakers: Silverline Bolero
Re: Copland CTA10 Pre Amplifier and CTA504 Power Amplifier (Sold)
Bringing up the post
» SOLD Copland CTA504 Power Amplifier
» Copland CTA301 tubed pre-amplifier and CTA504 tubed power amplifier (SOLD)Used)
» Copland CTA 520 power amplifier (Sold)
» Copland valve power amplifier CTA 504(sold)
» Copland Valve Power Amplifier CTA 501(SOLD)
