Subwoofer connected to Stereo Integrated Amplifier
Subwoofer connected to Stereo Integrated Amplifier Empty Subwoofer connected to Stereo Integrated Amplifier
Post by Jan Major on Mon Jul 18, 2016 12:52 am
Hi... i just bought a Onkyo A-9050 Stereo Integrated Amplifier and connected it with my Sunfire SDS12 Subwoofer and my Heco Interior 6000 plus floor standing speakers. However the subwoofer doesnt sound that excellent compared to when i connect it with my Onkyo TX 508 AV Amp. Tried all connections but failed to get a good sound from my A9050 Onkyo which is supposed to be a good amp. Request your advice guys. Thanks, Jan Major
Jan Major
Number of posts : 15
Registration date : 2016-06-14
Subwoofer connected to Stereo Integrated Amplifier Empty Re: Subwoofer connected to Stereo Integrated Amplifier
Post by Anwar on Mon Jul 18, 2016 7:52 am
Both the SR508 AV amp and A-9050 stereo amp are rated at about the same output power, i.e. 80W for 508, 75W for 9050, 0.08% distortion, 60 damping factor. But the SR508 has a bigger power supply since it is a multi-channel amp.  The limiter for the stereo amp is its 160W power supply vs 450W for the AV amp.  Also, you get better bass management (for subwoofer crossover) using AV amp.  When using stereo amp, full frequency range is being driven by the stereo amp whereas in AV receiver it depends on speaker setting (large or small).
Anwar
Anwar
Number of posts : 110
Registration date : 2011-01-08
Source(s): Marantz SA-10, Oppo UDP-205, Innuos Zenith Mk.II, TW Raven Two + TW 10.5 with Benz LP-S + Triplanar VII with Quintet Black, Audio Research REF Phono 2SE
Amplification: Bent Audio silver slagleformer preamp, Bryston 10B-SUB, McIntosh MC452 for front, MC303 for center and rear
Speakers: Focal Diablo Utopia 3 for LCR, Focal IW 1002 Be for rear, 2 x JL Audio Fathom f113 subs
Post by Jan Major on Mon Jul 18, 2016 2:35 pm
Thanks Anwar, great advice...
Jan Major
Post by atoz on Mon Jul 18, 2016 5:49 pm
In a stereo system, likely you will get better main-sub integration using the high level speaker input connections to your sub (s). Bass tends to sound slow and weak using line level preout connection even if you crank up the volumes.
Another method is to connect your sub direct to your rec-tape out from your amp but you will need to adjust the sub level every time you dial your amp volume.
atoz
atoz
Number of posts : 369
Registration date : 2010-01-30
Post by STC on Mon Jul 18, 2016 6:28 pm
It should work the same, have you cancelled the bass management in the int amp?
STC
STC
Number of posts : 415
Registration date : 2010-08-15
Source(s): Ambiophonics setup.
Speakers: Electrostatics
http://goo.gl/CF1C6B
